Eritas
I'm sure some of my posts could have been written better too.I re-read my posts from last night and I'm thinking that I was harsher than needed to be and I apologize for that. Anyhow, I'm liking where this threads heading as we are now having an actual technical discussion on merits on VLs.
The rubber really isn't all that thick and I can't tell if it's solid or not. I've done that too, but sticking a screwdriver though the hole and twisting it around (conical movement) is not representative of the load path when installed on the car. The vertical link is a compression/tension link. To feel the play of the bushing in this sense, you would need to try to compress the bushing by pushing down on both ends of the screwdriver, which would bend it. You really need a hardened bolt or rod and even then, you're not going to feel any play in compression. To properly test the deflection of the stock bushing, you need a potentiometer and a load cell to measure deflection vs load. It's not that difficult to do for any credible race shop or parts manufacturer. Then compare those results to aftermarket poly, spherical and delrin links.I took a picture of the backside of a stock VL and you can see that it has a good amount rubber bushing on the top side and I can stick a screwdriver through and wiggle it a bit. The bottom side has very little rubber and feels pretty solid. So my theory is that if you go with aftermarket VLs without supporting mods, you won't feel any difference because extra firmness will be observed by soft cradle bushings or as SlaughterOfTheSoul mentioned, by stock LCA bushing.
Once I get my subframe bushing inserts (which are amazing on my friend's car) I'll probably then back to back the poly VL to stock and see if it makes a difference then. Based on the Steeda video, the subframe bushings should be addressed before anyone installs a vertical link.
I'd agree with that. I'm pretty sure Ford's racecars use solid aluminum inserts on the subframe and diff, and probably have a lot of spherical bearings in the control arms. I'll have to go back to the Dean Martin GT4 page and check. But either way, I find it really intriguing that Ford changed out all of these bearings and bushings except the VL. Maybe minor compliance in that link helps put power down for road racing? If so, I still stand behind the idea that aftermarket VL's aren't necessary for street/HPDE cars. Maybe drag cars, but I don't drag race, don't know the needs of drag racing, or have seen failures or improvements from drag racing, or care much about drag racing. That's just an opinion (on stock VLs) and lack of experience/interest (drag racing), and no one has to agree with it.I know this isn't an apples-to-apples comparison, using an unscientific fingernail test, 80 durometer polyurethane inserts feel a bit firmer than the OEM rubber, and 90 durometer ones feel almost as hard as a rock. Not sure what's the rating for OEM rubber bushings, but this site says they generally range between 50 to 70 durometers. And since OEM rubber bushings are known to degrade over time, perhaps the biggest improvement comes from having a fresh set of bushings. I'll bet Ford race cars get their bushings refreshed often, if not between every race, unlike the street cars.
