Supercharger & lowing springs
Lbj
Washington court House OH
Larry
2019 mustang GT. A10 auto
I’m going to add a Roush supercharger but I have Steeda Progressive spring will there be any problems going supercharge with my set up
JK XLR8
Jupiter, Florida
JK
2021 GT Roushcharged
What kind of problem are you thinking.....I dont see how the two are related. Ive had stock suspension supercharged and lowered supercharged.....
Lbj
Lbj
Larry
Ok sorry I was thinking about the extra weight from the supercharger pushing down on the car
NJMike
2020 Jeep Trackhawk-2" Kooks, pully, CAI, cat back
When I had my 14 GT with a Roush, I also had Eibach Pro Kit ~ Front - 1", Rear - 1.5" + some beefy sway bar upgrades and it handled very well. Of course tire size should be considered for handling.
The car sat very level in this set up.
Frank
Ga
Franklin
2019 GT PP1 Kona Blue A10
I have the Steeda progressive springs that were on my car before I installed my Stage 2 Whipple kit with oversized heat exchanger. My wheels on the front are 20 inch and my tires are 285/35/20. Before the supercharger I had no rubbing at all but after the install when I come off a bridge or any pretty good dip the left front does rub slightly. I will move down to a 275 and it should be good. 2019 A10 PP1 CAR.
Whitedevil95
Temecula, CA
J.P.
2017 Mustang GT
I have BMR Drag springs and after my whipple the front end is a bit too low now. Difinitely dipped with the weight. I am swapping over to steeda drag springs to bring the front up a tad.
JK XLR8
Jupiter, Florida
JK
Eibach sportlines looks perfectly level to me with Roush2.
Stephen@lethal
2020 Mustang Gt500
The only issue you may run into is the front end may be a bit heavier and those springs may cause it to ride a little lower. BMR makes a spring specifically for this situation with a spring rate that accounts for boosted applications. If you have any questions, feel free to reach out anytime. Lethalperformance.com
Whitedevil95
Temecula, CA
J.P.
2017 Mustang GT
Yeah definitely look into this as well. When i bought my drag springs i was NA, I should have thought ahead and got the set made for blower cars.
Stephen@lethal
2020 Mustang Gt500
Yeah unfortunately I was given the NA drag springs for my turbo setup and it caused my tires to rub bad up front lol.
