"Suitcase" resonator questions...
Carzzi
'20 Rapid Red 401A PP1 A10 Magneride
Here's a video I found of what's inside the suitcase. The res is separated into two chambers. Interesting things:
  • Only one of the tubes is perforated in both chambers,
  • Only one chamber has fiberglass packing -- a chamber within which only one of the tubes is perforated
  • The unpacked chamber has perforations on both pipes, to allow for scavenging, but seemingly less efficiently than a true crossover (X or H)
  • There's no guided tubular crossover like in an H or X pipe.
bluestar
bluestar
Illinois
2018 Kona Blue Mustang GT
Thanks for posting! I was kind of curious as to what was inside of the stock resonator!
Carzzi
I'm considering a crossover myself and happened to be researching the same subject as this thread.
Andy13186
Muffler Delete.
Resonator Delete.
Install 28" glasspacks in place of resonator.
Enjoy the compliments, and the $100 exhaust job that sounds better than the $1k nonsense people buy.
The exhaust will then not be connected at all from manifolds back, would that cause any issues?
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Muffler Delete.
Resonator Delete.
You mean it'll sound like an old truck. Got it.
VikingJoe
DFW
2017 Mustang GT
I did the MAK cat deletes with an x-pipe and GT500 mufflers which ended up being pretty damn loud. I wanted to tone it down a bit to be more neighbor friendly so I installed the magnaflow tru-x resonator and it made my car so quiet that it was barely louder than stock. It works TOO well.
I ended up removing it almost immediately.
Andy13186
It's connected. I've been running this setup for 3 years and no issues.
Where in the system do the left and right sides connect with that setup? Also do you happen to have any sound clips?
HotBadgerFart
"Is it dead?"
ENC
Mustang
They don't connect.
I don't think I have any clips, because recording it won't sound the same. I can record tonight if you want.
