Suctioning noise when reving
Ores550
Woodland hills ca
Ore
2018 mustang GT
I have the roush catback installed on my 2018 mustang GT and I have noticed some weird suctioning noise when I rev in idle when the rpms goes back down I hear some weird noise wandering if this is normal and if anyone knows what's wrong.
thanks.
I have a video that you can hear it but it wont let me uploaded here.
showbbq
Houston
Check for exhaust leaks, but otherwise it might just be your intake.
Elp_jc
None
My Bullitt sounds like you're describing, so probably 'normal' for open CAIs. I don't like it, to be honest, but it's not a huge deal. Wish my car had the regular closed airbox, but it is what it is. Not going to change anything. Post the video on Youtube, then just post the link here. Curious how it sounds, and myself and others can tell you right away if our cars sound the same or not.
Ores550
Woodland hills ca
Ore
2018 mustang GT
It wasn't like that in the beginning I installed it 10 month ago but it started doing that few weeks ago I'm starting to think it might be a vaccum leak cause I feel the idle is lower and kinda late throttle response/loss of power
Elp_jc
None
That sounds weird. Are your valves vacuum operated? That might explain your suspicion, but to be honest, doesn't sound like a vacuum leak to me, but could be a really weird one. You need to crawl under the car while somebody blips the throttle, to determine where exactly it's coming from. You should be able to tell, since it's relatively loud. Good luck.
Ores550
Woodland hills ca
Ore
2018 mustang GT
Thanks I think I'll just take it to ford so they can inspect it and tell me what it is for sure!
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
That's the exhasut cam phasers. Deceleration rattle is normal on a cold engine. You shouldn't hear it once the engine is hot.
First Stang
2023 Mustang Mach1
It sounds like something loose or a foreign body rattling in the exhaust.
