Struts for GT350 springs
Chez
PA
2021 GT
I recently picked up some GT350 springs and I'm planning on putting them on my 21 GT.
Which struts should I use for this? Was looking at the pro actions from Steeda.
Thanks
Bluemustang
2015 Mustang Base GT
Ford Performance track dampers are direct replacement. Same spec as GT350.
Järn
The Motor City
Tony
2019 Mustang GT Premium, Ruby Red, A10, B&O, AE
Go to the vendor section and make a post in Levittown Ford Forum asking Benny for a discount code for free shipping.
https://www.levittownfordparts.com/sku/m-18000-f.html
I have these with Steeda Min Drop 200/800, they are just what this car needs.
You may wish to consider replacing the Rear upper shock mount while doing this work.
The OE part has a binding rubber bushing. Get a replacement with a bearing (I have Steeda).
Here are notes from a forum post from years ago...
Rear Shock Mounts:
Brian Mac: No rubber in the mount means the shock can develop its forces more quickly and control the car better. It reduces 'the bounce'.
Putting a bearing/rod end up there also allows for bind-free articulation as the arm rotates. It's mostly a vertical motion, but there is off-axis movement enough for it to be noticeable.
Järn
The Motor City
Tony
