Strut clearance
cechk01
RVA
2016 DIB GTPP
Hi All,
I have 285/35/19 tires on 19x10 wheels with a 40mm offset.
I put these on my front today and measured my tire to strut clearance to be only about 5mm. Is this enough?
Car is not lowered and on stock PP springs
Thanks
Optimum Performance
Gold Sponsor
Titusville, Florida
www.facebook.com
Tommy
'15 GT PP
Hi All,
Thanks
What tire exactly, actual size varies.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
TL;DR - Probably safe to drive, just check the tire sidewall after a bit for wear.
I've also got 285s on 10" wheels and I get a little temporary rubbing (visible on the strut) with about that much clearance. Asked the local speed shop about it and he basically said if its has not obviously damaged the tire you're probably ok. Keeping your pressures at 32 or higher is probably a good idea if you're worried about it.
Tire sidewalls rub curbs and other stuff and as long as its brief and rare (which it should be), the tire should be fine. I'll let you know if mine pops :)
cechk01
RVA
2016 DIB GTPP
Thank you....
I'll get a 5mm spacer if it show any signs of rubbing
scott_0
Oxford, Pennsylvania
you'll be fine
Shouldhavegotthegt
Phoenix
2016 Magnetic GT 2014 Ram 1500 RCSB 4x4
I've got MMD 20x10 45et and they cleared the front strut with a 275/35. Couldn't put the cap on without a 5mm spacer. I had some laying around from my last mustang.
That being said eventually bumped up to 20mm to get the wheels flush. Didn't like them tucked in.
