strange noise from passenger front wheel when turning left
tldukestang
tldukestang
Midwest
2016 GT350
I have a 2016 Tech Pack and within the last few days have noticed a strange noise from the passenger front wheel when turning sharply left at a decent speed. It's not debris caught between the caliper and the wheel and wondering if anyone has had a similar issue? I have about 10K miles and have tracked 3 times. It doesn't sound like tire contact and I checked for obvious restrictions.
Thanks in advance for your help.
raiderjatt02
Bay Area, CA
Jessie
2016 GT350 - Track Pack; 1995 GT - Saleen Clone
Is it a ticking type sound? Changes speed as you go faster or slower? Take your wheels off, then re-mount them and make sure it's torqued to 150lb/ft.
Hack
Minneapolis
Mustang, Camaro
If you want to diagnose it yourself, you want to get the car off the ground and mess around with the wheel looking for the issue. You are most likely looking for something that moves around or is too loose.
It could be a wheel bearing - look for play in the hub.
Loose brake pad.
Wheel itself (mounted incorrectly).
Caliper.
Those seem the most likely to me.
Or you could just go to the dealer and see if they can figure it out.
Edit: sometimes the direction/location of sounds can be deceptive. Don't completely lock in on the one wheel if you can't find anything wrong there.
Changes in the sound can help diagnose where it's coming from (brake issues will change when you touch the brakes, etc.).
Demonic
Boston
GT350R
Not the first time I've seen it mentioned on the forum, and every once and awhile I hear it on my car too.
torque124
Torque
MA
Shelby GT350R
Likewise, I am not sure what it is. I heard some strange noise turning into a multi-storey carpark where you hear everything with the windows dows... Took the wheel off, everything is torqued, re-torqued the wheel... I thought I fixed it, but then I heard it again.
482supersnake
Tacoma Wa
Mustang
2016 tech pack owner here. Same issue. My car has Stainless Works headers and others have suggested that it is from week motor mounts causing the motor to shift and getting a vibration / rubbing when turning.
ldp82
MA
GT350, Genesis 5.0 & 996 cab
For people who hear a sound. Is it like some one rolling an empty beer can between there hands (crinkling it)?
Demonic
Boston
GT350R
I'll have to find an empty can and try to see. Does it have to be a beer can or would any other beverage simulate it also?
ldp82
MA
Has to be beer, jack's abby works best. Kidding aside, any can should do it. :D
My car has made this sound (crinkling or fluttery) randomly in short burst and recently stopped altogether. usually while turning and from the front passengers side.
Demonic
Boston
GT350R
I wonder if it's the brake rotor pins. Which is normal.
I've heard the video of the movement of the rotor pins during cool down, and the sound I've heard sometimes is different. I think mine sounded more like when you put wider wheels and tires on the front and on full lock you hear the tire scrape the plastic wheel liner. I'm not saying that's what it is, just what I remember it sounding like to compare.
nastang87xx
Wisconsin
2016 GT350 Track Pack
Yeah mine sound like clicks. Almost as if like there's a plastic bar code label flapping against the wheel spokes.
