Why?I had to connect my tender via the fuse box.
This has been covered to death. Don't start it unless you're going to drive it. You do tons of wear idling a cold engine, and even if you see the coolant at temperature, the oil will never get there without driving. If you don't get the oil up to temperature, you won't cook off any moisture.I have mine in storage, i just start my car once a model on a warmer day above 32 deg.! I hope I am not hurt my car ? I do run it long enough to make sure everything gets to operating temperature!
Just starting it does it more harm than good IMO.I have mine in storage, i just start my car once a model on a warmer day above 32 deg.! I hope I am not hurt my car ? I do run it long enough to make sure everything gets to operating temperature!
becuase my trickle charger connectors are connected with eyelets. And the screws on the battery connectors can’t be backed out all the way. So I connected via the fuse box so o have a quick connect, disconnectWhy?
