Steeda Ultra Lite Linear Stance
Todd15Fastback
Atlanta, GA
Todd
2015 Mustang GT PP Fastback
Ebay.
I did a thread in this section with all details, do a search for spring pad spacer under my name it should bring it up.
But you just need E36/E46 BMW pad spacers in 6mm or 8mm, I went 8mm and when they arrive increase the inner diameter to 3.25" and then put them between spring isolator and cars body at top. :)
Thanks:cheers:
Gibbo205
UK
UK 2015 Mustang & BMW E46 M3
Thanks:cheers:
Found it:
http://www.mustang6g.com/forums/showthread.php?t=45193
Check replies as a few other US guys done this as well now with success and they linked to parts they got. :)
As our cars have a leverage ratio the ride height increases 50% over pad thickness so:
6mm = 10mm
8mm = 12mm
10mm = 15mm
12mm = 18mm
I went 8mm which gives me a 12mm height increase which you can see picture of before and after in above thread. When I go 20" wheels with 275 front and 295 rear I will see how it looks but with the 19" stance is perfect, nice rake and perfect wheel arch gaps with no change in handling. :)
Todd15Fastback
Atlanta, GA
Todd
Found it:
6mm = 10mm
8mm = 12mm
10mm = 15mm
12mm = 18mm
You are awesome!!! Me personally, I would do 6mm as 10mm is just below a .5" which would be perfect to me:thumbsup:
Gibbo205
UK
Yeah if the gap is a bit much on 20" wheels I can swap in a 6mm pad spacer, quite easy to do and spacers don't cost much. :)
Todd15Fastback
Atlanta, GA
Todd
I am in 20's now.
I just measured my fender height. My garage floor is level. Front sits ar 27 5/8' and rear sits exactly the same, 27 5/8".
Gibbo205
UK
I am in 20's now.
post up a side profile shot.
You want to match the arch gap in the front minimum and ideally have 3-5mm more gap in the rear to give true impression of rake. :)
ArrestmeRed
LI, NY
2016 mustang
Can anyone post up a pic of what camber bolts are used to be adjusted in the rear?
David@Steeda
United States
www.steeda.com
David
Bolt-on, slammed S197
wildcatgoal
@sirboom_photography
TBD
Can I be honest, I feel like the Steeda Ultralites (at least in the photos I've seen on this forum) lower the rear too much OR don't lower the front enough. I understand actual height is different between F and R fender, but I want the wheel gap to be much closer (to the same) front and rear. With these, I am seeing more gap up front than the rear. Can this just be the tire selection of folks? I'd be doing 275-35 and 305-35 tires.
Gibbo205
UK
Nope the rear drop is too much, hence why I used spring spacers.
In an ideal world the front would be an additional 5mm lower and rear 10mm higher in a perfect world.
But I love the stance on my car now with spring spacer.
Chad11491
Roswell, GA
17 Lightning Blue GT Premium PP
I think so too, to the point where I'm thinking of selling my NIB ultralights for something else. I bought springs to help get rid of the reverse rake, not keep it.
Gibbo205
UK
Why not do as I did and just fix it with spring spacer, they cost like $50
Chad11491
Roswell, GA
I just don't feel like I should have to spend more to "fix" the springs. Not knocking the springs or steeda. Steeda is great, and I'm sure the springs do a good job. But if I had seen all these pictures on the thread I would not have ordered these. Maybe the sport linears or something, as those pictures don't seem to have the reverse rake look. Not sure.
Schu
Las Vegas, NV
S550GTPP
I Have to disagree completely... the rear drop not only looks great, it's functional as well.
