Gibbo205
Hi there
I feel my ultralite linear springs sit ever so slightly to low in the rear, the front is perfect but the rear for me is a little low, here is a picture:
If I could raise the rear by 1/2" (10-15mm) I would have it absolutely perfect.
I did think of changing from the ultralite linears in the rear to the sport linears that Steeda offer as spring rate is same as Steeda claim the sport sit a little higher but cannot say how much. But at the same time my ultralites are supposedly lighter by upto 30% so I'd not want to lose the weight savings.
Which made me think about spring pads and isolators. Apart from going to the hassle of making something custom, does anyone know if any of the below would fit the S550 Mustang:
http://www.energysuspensionparts.com/universal-coil-spring-isolators.asp
Am in right in thinking if I put one of their isolators (remove the lip) on top of my already spring isolator that would give me the desired height increase in the rear.
If its hard to understand what I mean from that image then check this second image:
So in short I put the spring pad in that image where spring/isolator go with some energy lube suspension to hold it up there in place and then re-install the spring and isolator.
Am I right in thinking if I buy say a 1/2" spring pad, then my suspension height will increase by 1/2" ?
