Steeda Sway Bars for 18' GT, PP1 with MagneRide
Discussion in 'Suspension, Brakes & Chassis' started by Ecoboosted, Dec 25, 2019.
  1. Ecoboosted
    Ecoboosted Well-Known Member
    Vehicle(s):
    18' Mustang GT, 19' Road Glide, 06' F-150
    Feb 8, 2015
    Wisconsin
    1,300
    387
    0   0   0
    Hello All,
    I have a 18' GT, PP1 with MagneRide and want to get the Steeda adjustable front and rear sway bars. In the description it says
    "Front sway bar will fit vehicles equipped with MagneRide suspension but cannot be used at softest setting due to contact with factory ride height sensor."
    With the next stiffer setting on the sway bar does the car ride too stiff or harder on bumps etc?
    Is getting a rear sway bar worth it? I've read in another thread where someone said "Be a little wary of stiff rear bars. IMHO the common rear bars Steeda / BMR / Whiteline are on the stiff side even on low settings. Unless you have stiff springs or really know what you're doing, run the rear setting on soft, and the front on medium OR soft depending on how much understeer you want. If you love a tail happy oversteering car, then try medium on the rear bar, but be careful."
    Anyone with MagneRide and have Steeda sway bars what is your opinion of the Steeda sway bars?
    Thanks
  2. NickBlack
    NickBlack Well-Known Member
    Vehicle(s):
    2019 Ford Mustang GT PP1
    Jun 6, 2018
    Colorado
    249
    Bump! would love to hear from drivers regarding rear sway bar feel with magneride !
  3. EFI
    EFI Well-Known Member
    Vehicle(s):
    5.Br0
    May 19, 2015
    Boston
    1,865
    599
    Rating:
    100%
    2   0   0
    Swaybar stiffness and design has very very little to do with ride quality and harshness. Going full stiff for example you probably won't notice any difference when going straight, even over rough pavement. It's not like a shock or spring where if you go stiffer you feel the car get rougher.
    Any of the 3 settings on that swaybar will drive like OEM in terms of ride harshness.
  4. NickBlack
    Vehicle(s):
    Jun 6, 2018
    Colorado
    249
    Thanks I understand that completely, I was referring to how does it handle when you’re cornering and under hard acceleration out of a corner? Not in a straight line, they obviously don’t affect straight line driving. Thanks!
  5. Roadway 5.0
    Roadway 5.0 Strassejager
    First Name:
    Vehicle(s):
    2016GT PP 6MT
    Dec 19, 2016
    New York - USA
    974
    1,006
    Garage Profiles:
    Depending on your driving style and goals determines the settings. A medium front bar, as you apparently have to have it set to fit, won’t give you any issues; you may want at least a 350R or PP2 rear bar to balance things out. Of course adjustable bars give the most flexibility to easily change things.
    As for the rear bar, I’ve driven years now with Steeda’s big rear swaybar and love the dynamic with the Torsen LSD—makes for good fun on switchbacks. Keep it at soft or your inner tire will chatter on tight turns. It’s not for everyone though; most like a big front bar and a PP or slightly beefier 350R/PP2 rear bar.
    NickBlack likes this.
  6. NickBlack
    Vehicle(s):
    Jun 6, 2018
    Colorado
    249
    Thanks for the feedback...so for the Steeda big rear swaybar: do you have it set on the first setting? (softest setting)
  7. SteedaTech
    SteedaTech Well-Known Member
    Vehicle(s):
    2016 Mustang Q750
    Aug 8, 2016
    Pompano Beach, FL
    1,848
    1,284
    0   0   0
    Start off with the softest setting, which is the last or furthest from the bend.
    Steeda Tech
  8. NickBlack
    Vehicle(s):
    Jun 6, 2018
    Colorado
    249
    Thanks!
  9. Roadway 5.0
    First Name:
    Vehicle(s):
    2016GT PP 6MT
    Dec 19, 2016
    New York - USA
    974
    1,006
    Garage Profiles:
    Yep, the softest/first setting.
  10. LetItRide1978
    LetItRide1978 Well-Known Member
    First Name:
    Vehicle(s):
    2019 GT Premium
    Jul 18, 2019
    Columbus, Ohio
    105
    58
    0   0   0
    Can you elaborate on this? I have the Ford Performance bars (M-5490-G) and the rear bar is set to the inner (stiffer) hole. I am hearing a faint squeaking noise coming from the right side rear of the car when making hard right turns. The front bar was installed using the outer (softer) hole for some reason. May need to have one of the bars adjusted.
  11. Roadway 5.0
    First Name:
    Vehicle(s):
    2016GT PP 6MT
    Dec 19, 2016
    New York - USA
    974
    1,006
    Garage Profiles:
    The chatter I had was just the inner tire chirping. No squeaks to speak of. My best guess for your situation is a lack of grease on your rear swaybar bushings.
    Either way, it is generally a best practice to start a rear bar soft and then adjust as needed. I do it the other way around to be daring.
  12. LetItRide1978
    First Name:
    Vehicle(s):
    2019 GT Premium
    Jul 18, 2019
    Columbus, Ohio
    105
    58
    0   0   0
    Thanks for the clarification. I will see if I can see a difference between the two bushings. Should be able to tell if one side is greased more than the other. They are rubber bushings so I wouldn't think they'd be able to make this squeaking, m metallic sounding noise.
  13. Roadway 5.0
    First Name:
    Vehicle(s):
    2016GT PP 6MT
    Dec 19, 2016
    New York - USA
    974
    1,006
    Garage Profiles:
    Check the helper/tightly wound portion of your progressive springs for rubbing too.
  14. LetItRide1978
    First Name:
    Vehicle(s):
    2019 GT Premium
    Jul 18, 2019
    Columbus, Ohio
    105
    58
    0   0   0
    Will do, thanks!
  15. Bluemustang
    Bluemustang Well-Known Member
    First Name:
    Vehicle(s):
    2015 Mustang Base GT
    Nov 6, 2015
    2,859
    1,210
    Occupation:
    Financial
    0   0   0
    IMHO, keep the rear bar soft. This car doesn't need much more than the stock bar, if even that. You want to put down maximum power exiting corners. I think it's just how you are supposed to drive this car. It's not hard to put this car into power oversteer if you try. The stiffer front sway bar has much more benefit because of the poor camber curve of the front suspension. The stiffer bar will resist those front tires trying to curl back under and go into positive camber. More front camber and stiffer front bar is a good place to be. I would also advise not going too stiff depending if your tires are up to the added load or not.
Loading...
Share This Page
