Steeda sport or eibach sportline springs?
Enzo
Orlando
Enzo
2018 Mustang GT PP1
Here is mine on Steeda Progressive springs and adjustable pro action shocks w/ 25mm spacers all around. Highlyyyy recommend it! Car drives super smooth and handles amazing!
tj@steeda
Timothy
Steeda Camber plates are also available :)
Enzo
Orlando
Enzo
2018 Mustang GT PP1
The
Proaction adjustables?
pro action adjustable shocks allow you to adjust the softness and stiffness of the shock.
The camber/caster plates Vicr is talking about, replace the factory shock mount you would be switching over if you are upgrading your shocks and would give you or the shop the ability to adjust “camber” (how positive or negative the wheels poke in or out) and the “caster” (how frontward or backwards the shocks are aligned).
thebaldlatino5.0
Beeville, Texas
Carlos
2017 Ford Mustang GT PP
I'm wondering if Maximum motorsports camber plates fit the pro action adjustable shocks. Cause pro action has non adjustable and adjustable. I'm planning on getting the adjustables and i'm split between steeda camber plates, or maximum motorsports caster camber plates.
The
The camber/caster plates Vicr is talking about, replace the factory shock mount you would be switching over if you are upgrading your shocks and would give you or the shop the ability to adjust “camber” (how positive or negative the wheels poke in or out) and the “caster” (how frontward or backwards the wheels are aligned).
Enzo
Orlando
Enzo
2018 Mustang GT PP1
I personally would go with steeda on the shocks and springs. They are proven to work. The plates, is debatable if you need caster adjustments, which you most likely won’t. The camber I can understand. Plus steeda has amazing support and turn around time and lifetime warranty. I broke a part before with them and got my replacement in 24-48 hours. If you want the camber only and it won’t be extreme, you can also get camber bolts.
Bear_Stang
Country Roads, Texas
(SIG) 2019 Mustang Bullitt w/ non-mag SMcQ suspension w/ bullitt electronics / (SAUER) 2005 Ford Focus ST
PorscheHusky
Missouri
Evan
2015 Mustang, 1974 260Z
Sportline for me , I did add strut plates . Running a large tire set up with no rubs .
What width and offset are you running?
I just bought Koni yellows and next I'm wanting Eibach sport springs.
I plan to get SVE 500 wheels, 19x11 square or do you recommend another wheel size for track days?
fmc_smt
Cottonwood , Arizona
Fronts 20x9.5 45 offset . Rears 20x10.5 35 offset . The offsets might be reversed, I can never rember. I don't track , so o speak , just a roll on the street with a ricer here and there . Set up is more straight line then turns .
