sergeantbarber
- Sep 3, 2015
- North Carolina
- 2017 Shelby GT350
Yes dampers are completely adjustable separate of ride height. Steeda provides a tool that allows you to adjust rebound. Rebound adjustment is located at the top of each damper. The front dampers may be adjusted with weight on the vehicle. Just open your hood and make adjustments at the strut mount. The rear is a little different and will require you to jack/lift which will then allow clearance in the wheel well. Just reach your arm in and make adjustments with the tool at the top of each rear damper.
Turning full clockwise baselines towards full soft settings. Turning counter clockwise will begin to stiffen the dampers to your liking. It is not a difficult process, although the tool can be awkward to use, in less than 15 minutes.
