Blackhawk25
thank you for your reply, it is appreciated. do you have any feed back on the steeda minimum drop springs fronts 200 rears 750
It is false that all monotubes are a stiffer ride than twin tube. That's a nice marketing blurb, though. It also ignores the many benefits of a monotube design. Yes, because twin tubes have lower gas pressure, with everything else the same, they'll have a slightly more cushy ride. In this case, everything is not the same and the Ford Performance dampers do not have a stiff ride (chime in [MENTION=23614]SVT-DADDY[/MENTION], [MENTION=34621]udcvsean[/MENTION], others). Quite the contrary, actually. I've never had the adjustable Steeda dampers, only the fixed valve, so I'm missing that direct experience. I'd expect them to be very good, though, based on what SteedaTech has shared with me in the past.Ford Perf shocks will be a stiffer ride on the street as they're monotube. If you like a stiffer ride and are willing to risk having no adjustability to soften some of that out, they're a great option at a great price.
The Steeda shocks are twin tube, which is excellent for the street and will offer a more damped ride comparatively while still controlling the spring. I think the Steedas are the ticket.
If Bilstein could manufacture product and wasn't on some mysterious ridiculous backorder, maybe those would be worth trying but they can't seem to fulfill any orders.
Can confirm, the FRPP track dampers are more comfortable to me than the stock ones. Reason being the ride is firm and predictable instead of floaty. The ride quality just feels a lot better now.It is false that all monotubes are a stiffer ride than twin tube. That's a nice marketing blurb, though. It also ignores the many benefits of a monotube design. Yes, because twin tubes have lower gas pressure, with everything else the same, they'll have a slightly more cushy ride. In this case, everything is not the same and the Ford Performance dampers do not have a stiff ride (chime in [MENTION=23614]SVT-DADDY[/MENTION], [MENTION=34621]udcvsean[/MENTION], others). Quite the contrary, actually. I've never had the adjustable Steeda dampers, only the fixed valve, so I'm missing that direct experience. I'd expect them to be very good, though, based on what SteedaTech has shared with me in the past.
Oh, I don't get anything for saying any of this. Just sharing experience.
Marketing blurb... hilarious. :lol:It is false that all monotubes are a stiffer ride than twin tube. That's a nice marketing blurb, though. It also ignores the many benefits of a monotube design. Yes, because twin tubes have lower gas pressure, with everything else the same, they'll have a slightly more cushy ride. In this case, everything is not the same and the Ford Performance dampers do not have a stiff ride (chime in [MENTION=23614]SVT-DADDY[/MENTION], [MENTION=34621]udcvsean[/MENTION], others). Quite the contrary, actually. I've never had the adjustable Steeda dampers, only the fixed valve, so I'm missing that direct experience. I'd expect them to be very good, though, based on what SteedaTech has shared with me in the past.
At least THIS is true. :clap2:Can confirm, the FRPP track dampers are more comfortable to me than the stock ones. Reason being the ride is firm and predictable instead of floaty. The ride quality just feels a lot better now.
I'll just say this:It is false that all monotubes are a stiffer ride than twin tube. That's a nice marketing blurb, though. It also ignores the many benefits of a monotube design. Yes, because twin tubes have lower gas pressure, with everything else the same, they'll have a slightly more cushy ride. In this case, everything is not the same and the Ford Performance dampers do not have a stiff ride (chime in [MENTION=23614]SVT-DADDY[/MENTION], [MENTION=34621]udcvsean[/MENTION], others). Quite the contrary, actually. I've never had the adjustable Steeda dampers, only the fixed valve, so I'm missing that direct experience. I'd expect them to be very good, though, based on what SteedaTech has shared with me in the past.
:cheers:It is false that all monotubes are a stiffer ride than twin tube. That's a nice marketing blurb, though. It also ignores the many benefits of a monotube design. Yes, because twin tubes have lower gas pressure, with everything else the same, they'll have a slightly more cushy ride. In this case, everything is not the same and the Ford Performance dampers do not have a stiff ride (chime in [MENTION=23614]SVT-DADDY[/MENTION], [MENTION=34621]udcvsean[/MENTION], others). Quite the contrary, actually. I've never had the adjustable Steeda dampers, only the fixed valve, so I'm missing that direct experience. I'd expect them to be very good, though, based on what SteedaTech has shared with me in the past.
Please provide a source that has data that shows a well-tuned monotube is not comfortable for street use. I'll wait.Well here's your marketing then: https://www.tein.co.jp/e/special/ni_toryu/
