Steeda IRS Subrframe braces installation help
AnthonyA1234
Anthony
2019 Bullitt, 1992 Mustang GT
I purchased the braces for my 2019 bullitt and I’m confused on which bolts and washers go were. I also received different bolts then what they had on their YouTube video (no hex head bolt). Can anyone help me and explain what goes were?
AnthonyA1234
AnthonyA1234
Anthony
This is the brace I received. It also looks different to the one I see on their website as mine has large oval shaped holes while the one on the website and on youtube have smaller circle holes that fit the bolt better
NGOT8R
Adrian
2019 Bullitt
Here’s mine installed on my 2019 Bullitt and they are slotted just like yours.
Pic 1 - 50 mm bolt
Pic 2 - 25mm bolts
Pic 3 - (Front bolt = 45mm with nut on top)
Pic 3 - (Rear bolt = 12mm)
Note: The square threaded plate goes in the slot above the front bolt in pic 3. I didn’t use the plates in mine because I am running the differential support bracket on my car and the lower arms take the place of the square plates that you will use on your install.
AnthonyA1234
AnthonyA1234
Anthony
Great, thanks so much
NGOT8R
Adrian
2019 Bullitt
NP. You haven’t loosened the blue subframe bolts for any reason have you? If so, I’d check to make sure they’re torqued to 129 ft-lbs, before installing the braces.
AnthonyA1234
AnthonyA1234
Anthony
No I didnt, what would be the reason to?
