Steeda full length jacking rails don't fit
iTzAdren
Dallas,TX
Competition Orange S550
Trying to install the full length jacking rails on my 2015 mustang fast back but they don't fit. The inside bolt holes on my rails are about 38.25 and on my car are 37.25 what gives?
iTzAdren
iTzAdren
Dallas,TX
Driver side measures out correctly
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
They are not symmetrical. There is a driver and passenger side.
iTzAdren
iTzAdren
Dallas,TX
I measured both rails inside bolt to inside and they are the same 38.25 even though one rail is about a quarter inch shorter?
BmacIL
Enginerd
Naperville, IL
Not sure then. My BMR ones were different lengths L to R but fit perfectly. I'm sure Steeda will help you.
iTzAdren
iTzAdren
Dallas,TX
Yeah I guess I'm just bad luck everything I've had to do with my car recently has ended up in some scenario where something has never happened before or something alone those lines
Snakes&horses
2007 Shelby gt500 vert tungsten grey stripe delete black/red int.,2019 GT 400a PP1 A10 spoiler delete RR coupe
The rails are different lengths,I think the pass side is slightly shorter. If both rails you have are the same length than maybe you got 2 of the same side. Just a thought
iTzAdren
iTzAdren
Dallas,TX
Yeah one is shorter but the mid distance is too far. Idk
Snakes&horses
Maybe try switching sides? Otherwise I’m not sure. Mine went on fairly easy but you have to hold it up even against the bottom of the car and get a bolt started at each end. Even then I’d to wiggle the bolt and rail to get one to start. If it’s off just a little you could try to oblong one hole just enough. Good luck,I feel your pain. Things don’t always go easy lol
tj@steeda
Timothy
Some have had them on the wrong side, I have not seen an issue where they didn't actually fit :question: ... can you give us a call tomorrow to see what may be taking place? I will show this thread to our install dept. to see if they have any suggestions.
TJ
iTzAdren
iTzAdren
Dallas,TX
TJ
Yeah just called ill have to figure out how to do the pictures and get them over to you
tj@steeda
Timothy
BlownGP
Houston/Baton Rouge
Steven
Pontiac, Ford, Dodge
Did you swap them from side to side and or end to end.
I installed mine with angled support towards the inside. They went on, but when I was getting them tighten down it didn't sit right.
Had to fip them around.
iTzAdren
iTzAdren
Dallas,TX
Mine are different. #555-5212
