dwaleke
I'm not sure if you experienced oversteer or just lost the rear end under acceleration around the turn. IMO that's a different scenario.I have the Steeda sway bar set and had them on the middle setting for both bars. I nearly lost the rear end in the middle of a semi-spirited turn at a stop light, and probably would have lost it if the electronic nannies didn't kick in. Would setting the rears to the lower notch helped with that? Or would it have made it worse seeing how I would be promoting oversteer now correct?
A similar situation happened to me. But it also happened with the OEM GT PP setup (including tires) at the exact same location. My rear end would always give out in this same spot. Must be a really smooth portion of concrete in this spot or something. The stock suspension has some pretty bad understeer everywhere else.
