Steeda engine bracket to motor mount bolt inaccessible on passenger side with LT headers installed
NGOT8R
Adrian
2019 Bullitt
Has anyone installed Steeda motor mounts with long tube headers? I can access the driver’s side engine bracket to mount bolt from the engine bay to torque it down, but accessing the bolt on the passenger side is a different story. It appears that the passenger side bolt can only be accessed from the bottom (which is also going to be a challenge) with my LT headers installed. I need to torque the bolts to 41 ft-lbs. Has anyone else encountered this problem with LT’s installed? If so, how were you able to tighten the passenger side engine bracket to motor mount bolt? I didn’t have this problem when I installed the Bassani LT’s on my 2013 GT, as the header allowed the necessary clearance to reach the bolt from the engine bay. Thanks.
EPTS550
El Paso Tx
Jerry
2019 GT
A ratcheting wrench with a swivel end and set to German spec.
NGOT8R
NGOT8R
Adrian
2019 Bullitt
Copy that! I used ratcheting 15mm and 17mm wrenches to get it done to German specs and it worked perfectly.
