Steeda Clutch Spring Part Number?
rb92gt
Ponte Vedra, FL
2016 GT350 Cooled Tech
Looking to change to the Steeda Clutch Spring. I am finding multiple part numbers, can anyone confirm what I need for the GT350? Looks like there is a spring, a perch, or a spring/perch kit...???
Tank
9/11 - Never Forget
Above the Notches
G0853
This is what you want:
https://www.steeda.com/steeda-s550-mustang-clutch-spring-assist-35-lb-in-15-16-all-555-7022.html
It's just the spring and you reuse the existing perches. The two original springs get replaced with the one steeda spring. Easy procedure, move your drivers seat all the way back..Beware of the grease, bring paper towels :cheers:
Readfast
Fort Mill, SC
Tim
17 F350 King Ranch, 17 Focus RS
And Don't forget the pain killers for your back when your done. LOL!
It took me 3 mins to pull the old spring and install the new one. EASY!
Shift
CA
a Ford
If your small needle nose vise pliers has trouble gripping the short spring like mind did, grab a part of the spring along with the middle plastic perch used for the secondary small spring(you wont use it with the new spring, so if it gets damaged or breaks, no problem).
rb92gt
rb92gt
Ponte Vedra, FL
Nice!
Wow, what a difference, best $18 I ever spent. Who in the hell at Ford thought a double spring set up creating non-linear clutch feel was a good idea? lol. BTW, I used a small vise grips (non-needle nose) that wouldn't fit between the spring coils so I simply grasped the top and middle perches (which hold the stock larger spring) and compressed to remove.
GTthree50
San Francisco Bay Area
Magnetic Grey 2017 GT350
I'd like to give another Shelby with the Spring a try. I put in the Steeda spring and other than a very slight increase in pedal pressure I can tell no difference in clutch actuation. The stock double spring in my car is so smooth and light. I never felt anything odd or non linear with it. Thought the Steeda spring would be a night and day difference going off of all the high praise it receives. I'll be putting the stock spring back in to compare again. Maybe I just have a dead left foot.
