Squeal in front right when moving forward
AlphaTheBum
Jacksonville
2022 Eruption Green GT pp1
Noticed a squeal coming from the front passenger side when creeping up my drive way. Was not using the brakes at all. Not present at idle. Any thoughts?
Schuvwj
William
2025 Mustang 60th Anniversary Convertible
Wheel bearing?
ORRadtech
Atlanta, Georgia
Jack the car up, check the wheel bearings, check for anything odd, check brake pad thickness, see if brake squealer is touching the rotor.
Keeffa
australia
keith
ford mustang 2018 gt
Sounds like a stone stuck in there rubbing on rotor.
cerbomark
TN
20 GT PP2. 21 Mach1 (Sold)
I agree if you jack it up (and remove the wheel) you ll easily find what's dragging. Stone stuck, rear shield, brake pad or pad sensor or wheel bearing.
2016 Mustang GT PP w/ Voodoo
Right either the dust shield got bent slightly and is dragging on the rotor or a rock got in there.
somebody have that wheel off recently to mess with something? If so its probably a bent shield. Just bend it back with your fingers it doesnt take much.
