Spotless Water System
CompO5.sl0w
GTFO_0021
Martinsburg, WV
Trevor
2016 Mustang GT/PP / 2015 Jeep Rubicon
Anyone use something like this?
http://www.amazon.com/DI-120-Cr-Spo...?srs=8427487011&ie=UTF8&qid=1455124607&sr=8-1
Not having to hand dry my car is a big selling point and the Amazon reviews look pretty good.
I have the same thing, except the dual tank model on wheels. Works great like it's supposed too. I put a Y fitting from Lowe's on the outside faucet so I could still use the regular garden hose water and a quick disconnect fitting on one end and the other on the CR unit. Now I roll it out, quick-connect, turn on. I use the regular hose for initial pre-soak/wash and follow up with the spotless to rinse off.
You can leave it sit out in the July sun and won't have a single water spot as long as you rinse correctly.
daltron
daltron
Rowing All Day
Jonathan
2016 GT PP
Thanks! It does really look convenient and I feel like I am applying too much pressure when I had dry and leaving scratches.
jasonstang
Denver, CO
2017 GB GT/CS 6MT
Very interesting. So its like a portable water softener.
jasonstang
Denver, CO
2017 GB GT/CS 6MT
yea you are not supposed to press down when drying. just simply drag the towel over the surface.
CompO5.sl0w
GTFO_0021
Martinsburg, WV
Trevor
Actually, no. It's quite the opposite lol. A water softener uses saltinization to filter hard minerals to make it "softer" but leaves a fair amount of minerals and sodium in the water. Therefore still leaving a significant amount of minerals to be left behind as spots.
This puts the water through a "deionization" process that pulls every mineral out of the water leaving it pure water. It's so pure that they put warning labels all over it not to drink it, simply because there's no minerals or nutrients in the water that your body needs.
krazieboy
LA
JT
2016 Ruby Red EB, Manual, PP, Navi, 201a etc.
Trappen
Torrance, CA
2015 ecoboost premium
What is this you speak of? Washing a car at home by hand? I don't think they even sell garden hoses anymore here in California... :(
HoosierDaddy
Randy
I had the Costco 2-canister version but returned it. I think it may have something to do with the sealant/wax you use but the car still needed more drying than extra time it took to use the system. But I was already pretty damn good at getting the tap water to sheet off so maybe didn't have that much to gain.
But I do agree that you want the minimum paint contact with anything while drying so went with an 8HP heated air dryer that never leaves any water to remove by contact.
If anyone buys the system, be aware that they are sensitive to the flow rate of the water. If you don't have a pressure/flow gauge, you may need to fiddle with the knob on the bib to get it optimal.
CompO5.sl0w
GTFO_0021
Martinsburg, WV
Trevor
daltron
daltron
Rowing All Day
Jonathan
2016 GT PP
I called my water utility and they said while the outside watering restrictions are still in effect I am legally allowed to wash my car whenever I want as long as I have a shut off nozzle on the hose.
Big Sky
Montana
Pete
2015 GT Premium Ruby Red 50th appearance pkg
Leaf blower works for me and much cheaper
Gdyup50
Denison, Tx.
Ron
2016 GT Premium
How long does the filter, or whatever it uses last? And what is the cost to replace, refill it?
Big Sky
Montana
Pete
With the leaf blower I do have some touch up with a micro fiber towel.
