Sorry, another aftermarket amp question
Blackbeauty
Chicago
2015 mustang GT
Hello,
this is the most "electronically" advanced car I've owned and I'm a little worried about adding an amp to it. Should I add a capacitor? Will adding a 600W amp and subwoofer have any negative impacts on the electronics of the car? This being my first car with HID lights, is there any problems that can happen with the lights similar to older car halogens having dimming lights? Can I disconnect the positive end of the battery terminal (to attach the amp power cable) without worrying about throwing any of the computers out of wack?
Thanks!!
Shouldhavegotthegt
Phoenix
2016 Magnetic GT 2014 Ram 1500 RCSB 4x4
I've got a mono block for my sub and a 4 channel for the speakers. No capacitor and off the battery. Zero issues.
Blackbeauty
Blackbeauty
Chicago
2015 mustang GT
What's the total wattage? No issues either when disconnecting the positive terminal from the battery? Did you tap your speakers with a line-out converter?
Thanks!
Shouldhavegotthegt
Phoenix
My 4 channel is 250x4 and the mono is 750. Both Rockford prime amps. I didn't do the install. I know a guy that has a stereo shop. They did everything for me. They put the LOCs in the dash. They needed 3 of them total. The amps are mounted in the spare tire area since I didn't have a spare.
Blackbeauty
Blackbeauty
Chicago
2015 mustang GT
Did you have the base sound system to begin with? If yes, did you upgrade all the six interior speakers as well?
Shouldhavegotthegt
Phoenix
Yup. Rockford components up front and 3 ways in the back wired to the 4 channel. Rockford P3 12" to the mono
Markbnh1
New Hampshire
Mark
2017 Ford Escape & 2015 Ruby Red GT Premium
I'm running a 600 watt JL amp and Stealthbox subwoofer for a month now with no issues. The battery was disconnected during the install. It might take a few miles for the computer module to recalibrate after a disconnect but you barely notice it.
wildcatgoal
@sirboom_photography
TBD
You do not need a capacitor. Almost all of those big pill looking caps are junk. You need big copper wire and a working alternator.
