So when will someone make a gear drive
Konamoth
Atlanta, GA
Nick
2020 Mustang GT Base
It’s time the cam drive system and cams are tossed into the scrap pile of primitive thinking ?
https://www.freevalve.com/freevalve-technology/
I would second this. It seems like freevalve tech really should have caught on a looong while back, especially with how computer controlled modern vehicles are. I'd certainly take that over a whining gear drive. But—too little, too late.
sk47
North Eastern TN
Jeff
Hello; back in the day I knew a guy with a "rock crusher" transmission (Muncy???) It had a lot of gear whine. I always figured the gears were close to straight cut.
sk47
North Eastern TN
Jeff
Hello; there is a concern. A few times the computer controlled features of a car went screwy. The fix was to remove the battery cable for a bit and then the computer would reset. A friend had an early throttle by wire car. A 2003 model. We were driving along when the car would not accelerate above idle at all. Took off a battery cable and the car was fine after.
If the valve actuators could be set to fail with the valve closed, then it might be OK. That way there would not be pistons striking an open valve.
GregO
Illinois
S550 GTPP
Without an actual mechanical lobed cam to actuate the valves I’m speculating that if there was a piston to valve contact event there would be minimal damage.
K4fxd
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Gear drives are cool, less parts breakage, no chains, more precise - and I can deal with the noise - but it's just not for everyone...
Oh yea, I thought of the noise complaints. It would have to be aftermarket, or Ford performance.
With the war on ICE it will never happen. Too sad.
K4fxd
K4fxd
NKY
that thing would whine more than a millennial doing manual labor.
Not if properly set up. I switched probably 1000 twin cam Harleys to gear drive, none whined.
Muncie, I loved the several I owned.
Konamoth
Atlanta, GA
Nick
Kinda sorta. Remember there is still a big beefy pneumatic actuator behind the valve. It'd definitely not be as awful as solid metal pushing into solid metal three times over, but I can't imagine it'd just press the valve out of the way either. Suppose it'd depend how much pressure is being sent into that system to move the metal.
PhotoSHO
Houston, TX
Sam
2020 5.0 GT PP1
Anyone remember the Pete Jackson gear drive for the Windsor engines?
Little known fact but there is one Mustang does have a gear drive for cam timing.
Does anyone remember which Mustang had the factory installed gear drive?
GregO
Illinois
S550 GTPP
Strokerswild
Shallow and Pedantic
Southern MN
Things With Wheels
IIRC, the 2.8 V6 that was in the Mustang II used timing gears.
PhotoSHO
Houston, TX
Sam
2020 5.0 GT PP1
I believe you are correct, that was the old german Colonge V6. Neat little engine.
Actually the other one I was thinking of is the P-51 Mustang, which has a Rolls Royce designed V12 and it uses a bevel gear cam drive. Pretty neat engine.
GregO
Illinois
S550 GTPP
I’d guess the FreeValve to be very lightweight in design to achieve extended high rpm duty cycles. I’m unsure to be honest.
Speaking of the FreeValve concept turned reality;
https://www.motorauthority.com/news/1127582_how-koenigsegg-s-3-cylinder-engine-makes-600-horsepower
K4fxd
K4fxd
NKY
The old slant 6 mopar had a gear drive
K4fxd
K4fxd
NKY
Ford just rolled the EV F-150 off the line and a few months later, Bam, raw material increase to build batteries.
It's going to keep getting more expensive for batteries as the raw materials get harder to find.
