Slamming into gear?
steve_2020
US
2020 Ford Mustang
Curious if any of you have experienced your transmission shifting hard when you first shift into gear? Both forward and in reverse.
sk47
North Eastern TN
Jeff
Hello; Sounds normal if you go into gear when first started from cold. The cold start function of the programing does what a choke did on the older cars. The fuel mix can be some richer at start up. The RPM's are some higher for a bit. If you can wait till the engine RPMs die back down that should lessen the clunk.
you could also have the AC turned off at a cold start. Running the AC can have the engine RPM's up some.
My old car, a 2001 Sentra, revs over 1000 rpm's at cold start. Takes a bit for the revs to drop down to normal. My 2004 Silverado drops revs much quicker. I think one difference may be the O2 sensors. There have been improvements with the O2 sensors over time. The goal being to get them up to operating temperatures quicker is my guess.
steve_2020
steve_2020
US
2020 Ford Mustang
That makes sense. Had not thought about it immediately after a cold start.
sk47
North Eastern TN
Jeff
Hello; At the risk of opening a debate, this is what I do. With the auto trans truck, I tend to let it run for a while from cold start before putting it in reverse. Not a long time tho. Probably less than a minute. A bit longer on a bitter cold day.
I figure it allows for two things. One is to allow the cold start enrichment to start to drop the RPM's some as mentioned before. I do not let it sit running a long time tho.
The other is to let the pump inside the transmission circulate the trans fluid some. Especially on those bitter cold starts.
To your question. If the trans goes into gear with a hard clunk after the engine is well warmed up that may be something to have checked out.
MAGS1
Somewhere in Middle America
Mark
2022 Mustang GT
Manual or automatic?
MAGS1
Mark
2022 Mustang GT
I assumed automatic as well but wanted to confirm
Zooks527
2019 KB GT, 401A, 6MT, PP1, S&S, MR, AE, B&O / 2018 Jeep Grand Cherokee Summit
With the manual transmission, there's a "thunk" when you first slide it into gear from stopped (with the clutch out) as the transmission input shaft stops spinning when first or reverse are engaged with the car stationary and the momentum of the input shaft takes all the slack out of the driveline. May be something similar in the automatic.
MAGS1
Mark
2022 Mustang GT
It’s likely either with it being cold or you might be a tad low on fluid. Does it do it on a warm start or just cold?
FO 2/11
Rotonda Florida / From Chicago
Vincent
18 F-150 / 18 GT / 24 GT RTR Spec 2
Try revving the engine just a bit before you put it in gear and see if this eliminates it. I have an '18 GT that does this, and tapping the accelerator eliminates the hard shift.
GrabberBargeCaptain
CA
seems like that would indicate a problem with one of the clutches in the transmission
sk47
North Eastern TN
Jeff
Hello; Another bit of information needed. What is the resting RPM of the engine when fully warmed up? I am assuming the cooling fans are electric. If so do, they run a lot or even all the time?
Mike Pfeifer
Wesley Chapel, FL
2019 Ruby Red Mustang GT A10
Don’t forget about parking on an incline, this can also lead to this type of sensation as the driveline can be preloaded one way or the other, and cause the parking pawl to bind as it releases.
