Sintegrate Unit Discussion (Tips/Tools/Apps) - NEXTGEN Navigation added
zackmd1
Zack
[MENTION=22823]X0AYHAM0X[/MENTION]
What does the touch panel overlay cable look like? Is it that connector to the right of the LCD connector? Wondering if it would be possible to replace the touch panel with an antiglare glass panel instead of the glossy plastic panel that is there now. Need to know if it is a "4 wire resistive" or "5 wire". I highly doubt the panel is capacitive.
X0AYHAM0X
United Arab Emirates
Mustang 2015 V6
The whole screen is sealed and I don't think there's a way to change anything, even the cables come from within the back of it.
I found the 600 nit screen on eBay after contacting some sellers - just waiting for the reply to know how much.
poorfortune
Northwest Arkansas
Jeremy
'16 Base GTPP - Deep Impact Blue
That software is designed to use a Bluetooth OBD adapter, and was probably not designed to use OBD informati that is accessed through hard wired means. Changing that would need to be done in the main code of the program, most likely, if it is not an option to begin with.
EddieGT
San Diego, CA
Eddie
2016 Mustang GT, 2012 Challenger SRT8, 67 Fastback
Doesn't work on the Moddiction unit.
X0AYHAM0X
Mustang 2015 V6
Try to keep pressing on the word "Copyright" please.
It should be the same, Moddiction can take off the SD slot but there's no way for the software to be different.
[MENTION=6944]zackmd1[/MENTION] can you try this please?
EddieGT
San Diego, CA
Eddie
@zackmd1 can you try this please?
It lets you punch in the code. But when you go into the nav, it won't minimize.
EddieGT
San Diego, CA
Eddie
Maybe it was already activated, so if you do it again would it say "open map minimize" or "close map minimize"?
No matter how many times I do it every time it says open map minimize.
Redraven571
South East PA
Joe
2015 Mustang V6 Convertible Triple Yellow
Dunno why it's not working for you
Same here, not working on my unit either. Pretty much same as EddieGT, it looks like it accepts the code but it doesn't change how the app acts.
