Short term fuel trims?
strengthrehab
Houston
Ken
2016 DIB Base GT with PP
Ok because car is buried in a garage right now.
I'll try loading an alternate tune tonight.
strengthrehab
Houston
Ken
Swapped and then reloaded tune. Learn flag was at 0 and I wasn't able to take it for a drive/top-off yet. It was still running rough and same exhaust smell in the garage.
Anyone know the part numbers for the O2 sensors?
Any way that this is being caused by some catastrophic thing like compression loss? valve/timing issue?
I would think if those were a possibility, then the CEL/DTC would be apparent.
Dr. Norts
Ontario, Canada
2015 Race Red Mustang GT
Pull your MAF and clean it. A dirty MAF will cause high STFT readings. It's easy enough to do and definitely can't hurt.
strengthrehab
Houston
Ken
Yeah, I realized there was some fine "debris" from grass in my airbox and filter.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Did you check for vacuum leaks on the bank that's showing high STFT?
strengthrehab
Houston
Ken
I've checked all vacuum lines. Didnt spray anything though.
strengthrehab
Houston
Ken
Cleaned MAF without change. I then unplugged bank 2 o2 sensor (first one) and had no change in readings.
I'd think that means it may be bad.
Nuked
Morgantown, WV
2016 Triple Yellow GTPP w/Recaros
Log the O2 readings on both banks and compare. They should be about the same. 1.00 lambda at idle, give or take a couple hundredths.
strengthrehab
Houston
Ken
Yeah they are
Nuked
Morgantown, WV
Yeah they are
Do they stay consistent while cruising? If so and they are both reading then I wouldn't think it is a bad o2, possibly one lazy but it should show a different reading.
strengthrehab
Houston
Ken
Did compression test. Then did leakdown test. Cylinder 6 had 100% leakdown and air escaped out throttle body.
What is weird is the #8 plug was completely bent (electrode).
What's even weirder? Not a single code or DTC.
strengthrehab
Houston
Ken
Hopefully just an intake valve issue. Boroscope showed good pistons with no evidence of damage.
Taking cam cover off tonight.
strengthrehab
Houston
Ken
Boroscope of 6. Piston looks good.
strengthrehab
Houston
Ken
Another view3
