Shelby wheels
svttim
Wisconsin
2019 GT350R
i'm assuming i could run 305-30-19's all around with 19x10.5 and 19x11.
seems they are really built well then but maybe a bit heavy for track use...
I will use the carbons for track. I will buy a set of these for street
Rainier42
Bucks County, PA
2019 Performance Blue GT350R
I like the look of these wheels and would consider them but the caliper clearance is not good.
orangegrower
Cave Creek, AZ
2019 GT350 - 2019 Aston Martin Vantage - 2019 Ranger Lariat
Do you know this to be a fact??? I have the wheels and the clearance is no worse than stock.
Rainier42
Bucks County, PA
svttim
Wisconsin
2019 GT350R
which color you going for? The smoke tint or the brushed aluminum? I can't decide which would look better on a black R...
Ill probably go with the smoked but, I like either. Saw a polished set on a base car and they looked awesome
Bullitt40
Fl
2016 GT350/track pak
think 305-30-19's all around with these 19x11 + 19x11.5 will work good? or better to go 305 fronts and 325 rears? whatcha think?
i do like the smoke tint set. this is tempting me from another set i was about to go with...
Not sure these wheels fit the R model. Better check
nastang87xx
San Diego, CA
2016 GT350 Track Pack
Not catching little pebbles.
a'' 19's can catch pebbles between the barrel and the front calipers.
305/325
And you'll need open end lug nuts but otherwise you'll be fine.
nastang87xx
San Diego, CA
brain freeze. correction. the wheels are 19x10.5 and 19x11, that is why i mentioned going 305's all around or 305/325.
I ran 305's all around on my stock wheels before. Profile was definitely low but it was fine. You can run 305's and 325's on 10.5 and 11 but absolutely no more. If you're tracking you might get a few funny feelings here and there but if it's just a street application, you'll be fine.
