Screeching noise when accelerating/letting off the throttle
T Amplitude
New Jersey
Trevor
2020 Shelby GT350
I’m planning on going to the dealership soon and having them check it out, but I figured I would ask on here first.
Car is a 2019 GT PP1. Initially there was a screeching noise when I let off the throttle after accelerating quickly, at around 3500rpm in 2nd or 3rd gear. Over time the noise started happening when I accelerate quickly as well, anywhere between maybe 3000-4500rpm in 2nd or 3rd gear primarily, but it has happened in 1st and 4th as well. I can’t really figure out where the noise is coming from because of how high pitched it is, but I think it’s from the rear. The noise doesn’t happen every time I accelerate and it doesn’t seem to be tied to how warm or cold the car is.
I’m hoping someone could point me in the right direction, any help will be appreciated.
T Amplitude
T Amplitude
New Jersey
Trevor
2020 Shelby GT350
Can you please post a video with the sound?
I tried uploading an mp4 but apparently it is too large, I trimmed it as much as possible it's still too large. Then I tried an mp3 because the sound is all that really matters but it said it's not an allowed extension. Do you happen to know what I can do instead?
usgiorgi
Fairfax, va
C6 Z06
You can upload it to youtube and then link the video here.
T Amplitude
T Amplitude
New Jersey
Trevor
2020 Shelby GT350
Alright thanks. This is the noise while accelerating in 3rd gear although it was hard to pick up on video:
Hope it helps somewhat. Something I meant to mention originally, but forgot, is that the noise seemingly appeared after installing a Roush cold air intake but I wasn't sure if it was just coincidence or not as the sound has gotten worse over time.
usgiorgi
Fairfax, va
C6 Z06
I hear the slightest whistling sound around 3 and 4 second mark. It sounds like the air intake actually. My JLT had the same sound as well. Take the intake off and see if the throttle body is dirty at all. A dirty throttle body can also cause whistling sounds.
I'm positive it's your intake though. Check all the connections and make sure it's tight after you check the throttle body.
T Amplitude
T Amplitude
New Jersey
Trevor
2020 Shelby GT350
Thanks I'll definitely check everything over. Although, the video makes it sound more like a whistle whereas in person it's more of a screeching noise. Not really something you would normally associate with intake noise.
T Amplitude
T Amplitude
New Jersey
Trevor
2020 Shelby GT350
The noise turned out to be part of the cat back rubbing against the bottom of the car by the way.
twotone5.0
Southern California
2018 GT Premium 10R80 (400A)
Thank you for this! Will check my catback. Where was yours rubbing at?
Neborb
Bryce
Premium 2020 Mustang GT
@twotone5.0 Did you ever figure out what the exact issue was? I'm noticing a small sound (almost like a belt squeal but it sounds like its coming from the back of the car, i could be wrong tho, i only hear it when driving) when accelerating around 2k-3k RPM at speeds around 15-25 MPH. After work today I'm going to check out my exhaust and see if it's rubbing against the car but I just wanted to figure this out before bringing her into a dealer.
My stang:
2020 Mustang GT Premium Convertible
Rapid Red
Woodstock GA
Greg
Yes he did reread the thread,
Dark5oh
Utah
Jake
2021 GT
My stang:
Hey man did you end up getting this figured out as well? Im getting a really weird Chirp/Squeak primarily in 1st and 2nd gear around the 3k rpm range almost sounds like a pulley squeak but only happens when driving in those ranges. Super noticeable when driving next to a wall with the sound reflecting off. It only has 5000 miles!!
Neborb
Bryce
I believe it's like the others said. I think it's a part of the exhaust rubbing against the body of the car. Especially since it's coming from the back for me.
If I were you try confirming if it's the front or the back. The back means it's most likely just something "simple" like a cat being slightly loose.
I'm waiting to bring her to the dealer with my next oil change so they can give a look. I'm not too worried atm.
