S550 Electrical Issue
jev0918
Louisiana
Jody
2016 Mustang
Any help or advice would be appreciated
Car stumbles and sometimes dies at idle after warmup runs good driving if u kill it and get back in and start it up u have to turn it over for a few seconds and touch gas to make it start smells rich, also when you close door and window seals car wants to die.
Car is SC have a lot of new parts
Any suggestions
jev0918
Louisiana
Jody
2016 Mustang
So brand new DW 400 FP
Window motors, Alt, Crank Sensor, Bosch ID 1050 Injector, plugs etc
SBR70.3
Edmond, OK
2021 Mach 1, 2023 Explorer ST, 2019 GTI (back up track toy), 2026 Colorado ZR2
I have to ask the obvious question, was the fuel system installed correctly?
How long have the s/c and associated mods been on your car? When did this problem start?
jev0918
Louisiana
Jody
2016 Mustang
Yes sir I have a fuel gauge on rail it never changes until it kills
Bought the car Oct of 24 already had SC and mods except injectors and FP so it’s been like this since I purchased it so I think it’s electrical something between shutting door circuit and timing changing I thought maybe someone heard of this thanks for asking makes me think about it
NGOT8R
Adrian
2019 Bullitt
Does your DW400 have the check valve in it? I bought one for mine (which must have been an old unit sitting on a shelf in the distributor’s warehouse) that didn’t have the check valve in it. Lack of a check valve can cause hard start issues during warm starts. I ended up adding a DW inline check valve to remedy this issue with mine.
sloopy
DFW, Texas
Black 2015 Ford Mustang GT PP MT82
I would replace the battery if you have the money. A failing battery can cause strange issues even if it still holds a charge well.
Paddles
TX
Richie
2023 Mustang GT
Any suggestions
Almost sounds like alternator/battery not providing enough power. Could be causing a weak spark. Already check your grounds?
Does rolling both windows up or down at the same time cause it to stumble even worse or is it only when closing the door?
Is the new battery/alternator OEM?
See any electrical arcing in the engine bay in the dark?
jev0918
Louisiana
Jody
2016 Mustang
When both are up and you close either door it stumbles
alt- OEM new 14.2 constant
Battery OEM New
Not that I see I went over it pretty good grounds I checked all of them cleaned paint and retighten I am at a lost withnit
eisenhauer01
Walkertown, NC
Kenny
2015 Mustang GT
Does any other load (headlights, brake lights, ac compressor) make any difference? Or is this issue solely isolated to the window motor load when going all the way up?
Does the same issue present when you put the window all the way down?
What is the voltage reading when running (fine) and then what does the voltage drop to when you close the door or roll a window up?
Could be multiple things, but these answers can help us isolate the problem.
jev0918
Louisiana
Jody
2016 Mustang
Voltage stays consistent 14.2 14.1
Lights on ac on same 14.1
I’m thinking maybe BCM back feeding ECM causing timing to go nuts I have data log the issue tuner thinks it’s electrical causing timing issue
