Rxt clutch installed did I do something wrong?
doodguy
Ruskin, FL
2015 Roush Stage 1 Supercharged Mustang GT
Installed rxt clutch with stainless line got everything together, primed clutch yesterday pumped a thousand times, reservoir full, today checked pedal went straight to floor.
Is this normal air making its way out? Does car have to be on when pumping clutch? Does it need to be started? I don't see any fluid leaks or anything
Anthony 05 GT
Northern Harford County Maryland
2005 Mustang GT, 2015 Mustang GT Premium
I have not seen that, but I would jack up the driver's side of the car about 10'' off the ground and begin by pumping the pedal extremely slow, like 5-10 seconds per stroke. This gives any trapped air a chance to move up through the port in the master cylinder as the piston passes by. Too fast of a stroke closes the port quickly. Once the pedal begins to stiffen increase your speed to about 2-3 seconds per stroke. This can take a while, but if this problem continues you could have a cylinder problem.
Jacking the driver's side up allows air to escape from the elbow line that goes through the bell housing on the older cars so I'd imagine it is similar on the '15. No need to start the car, all hydraulic.
doodguy
Ruskin, FL
I pumped til pedal back last night, today, went back and pedal pressure still there so guessing was just air still working it's way out which is great! I really didn't want to pull transmission back out.
Anthony 05 GT
If all the hydraulics are good you should be ok. Any air left in the system will work itself out as you drive. Good luck with it. You will love that clutch set up. I wouldn't run any other than McLeod.
Grimace427
NoVA
2011 Mustang 5.0
Yes you will notice after letting the car sit overnight you will have to pump it up again. After that it should be good. I've done a few clutch line installs on 2011+ Mustangs and they've all been the same way.
doodguy
Ruskin, FL
Thanks! Had me worried. I feel more confident todayou since it's holding.
smokinzx14r
ST Petersburg FL
Lee
2015 GT A6 3.55 Gears ..
Mine did the same thing , a few days of driving fixed the problem ...
proamas
Tampa, Florida
2015 Mustang GT 50 Year Package
Hey guys, does the car need to be running when you pump the pedal?
doodguy
Ruskin, FL
No. Just pump it a lot. I pumped mine for like an hour
Anthony 05 GT
Pump it real slow at first. That allows air trapped to escape up through the master cylinder port.
proamas
Tampa, Florida
That worked like a charm. Thanks
