Rubbing on eibach coilovers
50coyot
Long beach california
Gus
Red s550
Need help, i just installed my eibach coilovers and the tire rubs. Im running the 6gr 5 spoke 19/10 with 295/35/19 michelins. Should i get spacers? If so what size? I tried the coyote 1” and tire sticks out too much. Or am i gonna have to get diferent tires?? Thanks
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Raise the car till it doesn't rub. If it's rubbing on the strut, try a 5 mm spacer.
EFI
Masshole central
5.Br0
Where is it rubbing (fender or strut)?
Did you get it aligned or checked the camber?
50coyot
Gus
Red s550
Its rubbing on strut right below the coil no i have not aling it yet
Grintch
Hunstville
2015 GT PP
Eibach coilovers (with adjustable spring perch) or just springs (and maybe shocks)?
295 is where it starts getting a bit hard to fit up front.
Are the 5 spoke 6GRs +35 like the GT350R replica 6GRs?
With +35 offset, I would expect worse case they will fit with a little spacer and camber adjustment assuming stock style shocks. With coilovers, sometimes the spring perch ends up in exactly the wrong spot for tire clearance, which introduces a whole new set of issues.
