Roush Phase 2 Dyno Numbers
altjx
GTFO_0036 | 1337 h4x3r
Posts
3,702
Atlanta, GA
www.altonj.io
Alton J.
2017 Race Red GT350
Anyone get phase 2 installed and have dyno numbers by chance? And can you also let me know if you have the vmp heat exchanger and Roush's calibration?
Advertisement
davidryan1987
Posts
98
Houston Texas
David
2016 Mustang gt Supercharged
Phase 2 numbers
Just got my car back today and the numbers for my phase 2 upgrade and they where lower than my phase 1!!!!
Car was on dyno with phase 1 and they left it on the dyno and installed the upgrade then re dynoed it again. The numbers are below.
Phase 1: 546 hp 493 torque
Phase 2: 548 hp 473 torque
What a waste of money and time. I will be contacting Roush to see what is the deal.
The guys at the shop that did the install and dyno said the timing in the tune is way low.
BMR Tech
Gold Sponsor
Posts
5,127
Tampa, FL
www.bmrsuspension.com
Dion
^ I am going to guess heat was the issue.
Run a TVS car hard, then shut down and sit....it heat soaks BIG TIME.
Once that heat soaks in, it will make less and less power from pulling timing.
davidryan1987
Posts
98
Houston Texas
David
It is hot in Houston But the phase 2 upgrade was done after the phase 1 dyno was ran. The install for the phase 2 parts at least have to take a few hours to install so it should of been cooled down.
altjx
altjx
Posts
3,702
Atlanta, GA
www.altonj.io
Alton J.
2017 Race Red GT350
  • Thread starter
  • Thread Starter
  • #5
Wow man, that's pretty weird. Definitely doesn't sound right at all. I was making 601rwhp and 500rwtq on Phase 1 with Roush's calibration for the 670hp update or whatever. Just finished installing Phase 2, added a VMP heat exchanger, and also went with an aftermarket tune (lund).
Car runs absolutely perfect and the loss of power that I feel sometimes is definitely related to the heat out here. I can drive the car for awhile during cooler nights and it still feels great. Today with it being 100 degrees outside, I tried to merge into a lane after sitting in stop and go traffic for 15 minutes and it felt like a bus trying to get on it a bit.
Going to an event tomorrow with a few forum members and can't wait to see what I'll be putting down.
Keep us posted on your troubleshooting process [MENTION=24084]davidryan1987[/MENTION] if that's cool.
davidryan1987
Posts
98
Houston Texas
David
Will do let us know what you put down also.
How much trouble was the aftermarket tune?
MikeD1
Posts
1,171
Central FL
2016 Challenger Hellcat
Actually, your Phase I #'s seen on the low side. But dyno runs can be affected by so many varibles.
Here's what Brenspeed pulled on their install:
altjx
altjx
Posts
3,702
Atlanta, GA
www.altonj.io
Alton J.
2017 Race Red GT350
  • Thread starter
  • Thread Starter
  • #8
Will do! Honestly the aftermarket tune was extremely easy. You just buy an ngauge, and Lund sends you an email with instructions -- rev the car to 2500, 3500, 4500, send them logs. They send you a tune revision and on to the next step. It's actually pretty fun too. Gives you a reason to go WOT lol.
Also when you have questions they're responding to you within a matter of minutes for the most part. No need to call anyone.
Again, very easy. Going to lose the warranty with Roush but eh. Already losing part of it anyway if you bought it for phase 1 and plan to upgrade.
Stage_3
Posts
5,975
MA
2019 Roush Stage 3
What a waste of money and time. I will be contacting Roush to see what is the deal. The guys at the shop that did the install and dyno said the timing in the tune is way low.
Wow,....something is definitely wrong. :tsk:
What shop did the install? I "assume" it was a Ford Dealership for them to download the tune from Roush. The only other ones I know of that can tune the Roushcharger is VMP and Ken Bjonnes, (Palm Beach Tuning).
davidryan1987
Posts
98
Houston Texas
David
Psi motor sports in Webster Texas.
They did use the Roush voucher and downloaded the tune. Weird thing is same car as mine was in there for the same upgrade and did the same thing. His hp was around 580.
Thinking about getting the Lund tune but need to do some more reading up on it.
davidryan1987
Posts
98
Houston Texas
David
I'm guessing you can use the sct tuner vs the Nguage? Do you find yourself using that guage for anything else except loading the tune?
davidryan1987
Posts
98
Houston Texas
David
They may be a little on the low side the shop said beacuse the 3.31 gear swap I did in my car and the Roush tune speed limiting the car to 150 mph. They say they do the dyno in 5th gear so I'm guessing it maxed out at 6000 at the 150 on dyno.
MikeD1
Posts
1,171
Central FL
Not to be insulting, but did you adjust the RDT for the 3:31's when you layed down the tune?
davidryan1987
Posts
98
Houston Texas
David
Rdt?
If you are referring to using the whipple tool to change the gear ratio in to computer them yes.
Anyone have any pros or cons on either the Lund vs vmp tune?
MikeD1
Posts
1,171
Central FL
RDT is the Roush tool used to lay down their tune & it needs to know the correct gear ratio as well.
Advertisement
119 - HP Tuners - 1
Advertisement
