Ridetech Level 2 Coilovers installed:
gtorpedo
Arlington, Virginia
2015 Mustang GT Premium PP
I am half inch in the front an inch-and-a-half preload in the rear. Do you have aftermarket axles?
Thanks, that seems like it would work out nicely..1/2" preload with the 400lb springs in the rear is just too low IMO. I have factory halfshafts so no clearance issues.
Also, what have you all torqued the center top nut on the front coilover to - that wasn't mentioned in the Ridetech instructions?
Khyber
it's a hard parked life
Lexington/Myrtle Beach, SC
Landon
2015 GT PP CO
looks so good!
Schu
Las Vegas, NV
S550GTPP
I've been getting some installation questions about this kit. The instructions are pretty good, but I threw this video together to discuss a couple of important points.
Very helpful... thanks
So the impact will tighten the nut while a slow turning ratchet will not?
RidetechJosh
Jasper, IN
1993 LX Mustang, 2003 Mach 1
Correct. When using the impact, the high torque allows the nut to tighten down without spinning the shock shaft. If you're using a standard ratchet, the slow turning lets the shaft spin and won't allow the nylock nut to thread on all the way.
gsxr1300
MA
Jason
2023 Mach 1 2015 Mustang GT PP (Sold)
Sharad
Josh figured out why I had rubbing with the axle boots, I was accidentally shipped 10" rear springs instead or 8" like I can see you have by the part number on your rear springs.
gsxr1300
MA
Jason
Next I am going loosen the front top strut mount bolts and slide them towards the rear like you mentioned.
Niz55
Us
17 GT350
The 10 inch is the correct spring when the coilover was designed. Now with people having rubbing issues with the FRPP half shaft Josh changed it out so we can run 8" like the front.
gsxr1300
MA
Jason
I think I'm the only one that was rubbing, Sharad, Guard5.0, both bought their parts before me and have 8" springs.
Niz55
Us
17 GT350
I just bought mine 3 weeks ago and it came with 10".
gsxr1300
MA
Jason
How did you set you caster in the strut mounts?
Niz55
Us
17 GT350
Max caster. Push the strut assembly towards the front of the car
