DickR
We old timers from the points ignitions and carburetor days had to rely on various ignition cut rev limiters. The most basic types use centrifugal force to short the current to the distributor rotor tip. Google Lucas and Bosch rev limiter rotors if you care. These are NOT "soft" and may contribute to engine wear. I used this type on my Lotus Europa. I could raise the rev limit by drilling holes in the movable shorting bar.That is called a soft cut or throttle cut.
A hard cut is when the rpm bounce back and forth because ignition cut.
There are also more sophisticated ignition cut rev limiters that control which cylinder gets cut such that the effect is actually pretty smooth. I used a couple of different versions of these on my Formula Ford which had a carb and points.
https://www.pegasusautoracing.com/group.asp?GroupID=IGNREVLIMIT
https://www.google.com/url?sa=i&rct...UUn0nELNOyZs5urnxttJz4TQ&ust=1505873106002007
Note that the commentary with the Lucas pictures gives rpm limits. Those are 1/2 the engine rpm.
