Restoring stock ACM programming - Forescan
Bsingh897
California
2017 mustang gt
Hello,
I did some changes to my Forescan programming for my 17 GT since I added aftermarket speakers and a subwoofer. However, I'm selling the car and returning everything back to stock. I put the stock speakers and removed the subwoofers and amplifiers but the sound is too low. I believe it had something to do with the ACM of me tuning the low-level output. I just need the correct programming code to restore everything back to stock.
These are the line codes that I changed. Just need the original value to restore it back. I broke the computer with the forescan software so I'm not able to register it back to default.
2017 Mustang GT 301A base package
My VIN code is: 1FA6P8CF8H5259487
Current line codes that i changed. (need the stock value of these lines)
727-01-01 D850 2800 0030
727-01-02 0000 32
727-02-01 2E5F
727-03-01 4E80
727-04-01 0003 0255 53E0
Nagare
Ft Lauderdale
2017 Lightning Blue V6
Go to the motorcraft asbuilt website and use your VIN to download yours and compare what you need to change, it varies based on the options.
If you had an amp, that could explain why you think it's so low too. I remember when I had my Corolla I would usually listen at around 10-13 at the highest, when I took out my amps/speakers, I needed to be at like 30 to be similar.
