olaosunt
Thats just nuts at that price —could be as high $60K if you tick all the options . That’s a littleSpeaking of, Brenspeed just laid down 1000 big ones with a Whipple and a '16 car. To be fair though I fully believe this particular car is absolutely on borrowed time. That's a lot of nut on a stock motor. But hey, they did it.
less than just adding a base GT 500 to your stable .
I have a Gen 3 Whipple on my 2016 tech pack and ended rebuilding my stock motor(had billet OPG/CS before ) after bending a couple of rods, running the whipple tune /race gas and only a 3.5 pulley .
Not sure what caused it but the whipple tune is suspect . I think I also fouled my 02 sensors running leaded race gas after deleting the cats and car had been missing before the rods bent .
New motor is back in the car now and it’s running like a champ . It’s a similar build to the one in the Brendspeed car but rods are Manley H with 2000 bolts .Also have return fuel system with 3 pumps /ID1300 and upgraded the clutch to twin disc Spec SS.I already had CF one piece drive shaft before the rebuild and also run around on MT SS drag radials .
I have about 1000 miles on the motor and no dyno but it pulls strong per my butt dyno with a 3.25 grip tech pulley and the tires will hook even in mid 40 degree weather . RPG warranties the motto for year @1300 hp .
Summary of engine build below .
I did also do the PAC springs upgrade .
One head was replaced after FedEx dropped the motor at first attempt to ship it back (builder decided to replace to be safe )
Thanks to Will@ RPG again .
I can assure you I have not spent close to the Brendspeed quote and consider the engine to be as reliable as you can get .... but just in case I have a “back up “ engine getting rods /spring /head studs upgrade . Lol
Might also be building a short block with the new Predator block so I have a “back up “ for the “back up” .
I plan to keep the car for ever and if I don’t ever need the back ups I am sure I can find some other use for them or sell to anyone who needs one quickly . Lol
