nastang87xx
So another GT350. Got it lolPrice is still nuts thought .
That’s even more than the Fatfab1400 R package
Nice .My 2017 is still running strong. Over 16000 hard miles on the current Whipple setup and 3.625 pulley. The only problems Ive had were with torn CV boots and I burned up the factory clutch last weekend. Not bad for a 850rwhp car on pump 93.
I used to think it was a lot of power of 93, but it doesn't knock even at 18.5 degrees of timing so I trust it now. In the past Id run MS109 and I have a meth system on the the car but I hardly fill the tank these days.Nice .
Do you think that’s a lot of power for 93 ?
I think the best thing one can do other than swapping OPG is also to get a an aftermarket tune .
I think my stock engine would may be have survived if I did that .
I thought E85 would also help but who needs that if you can make that kind of power on 93 .
Have you ever run it at the drag strip ?
If you have what does it trap in the 1/4 ?
Nice . How much boost with the 3.625 pulley do you see ?I used to think it was a lot of power of 93, but it doesn't knock even at 18.5 degrees of timing so I trust it now. In the past Id run MS109 and I have a meth system on the the car but I hardly fill the tank these days.
I don't trust the e85 in my area, the quality varies greatly season to season. I think a lot of guys get tuned to full kill on quality e85 and then end up blowing their cars up not knowing the were running pump station watered down e60 or lower.
Im still on a Whipple based tune. Its been gutted and changed but the airflow and fueling tables are still the same.
This current setup has gone bottom 10's @ 143 on Nitto NT05r's
My boost gauge says 11 maybe 12ish on the 3.625, and yeah I have kooks stepped long tubes and full 3" Magnaflow exhaust.Nice . How much boost with the 3.625 pulley do you see ?
Stock exhaust or long time headers ?
I think you could exceed those goals by 150hp on the stock whipple tune on 91.....What’s the consensus on a pump gas tune from lund, pbd, and only wanting a mild 650-675.
Thats nothing for these enginesWhat’s the consensus on a pump gas tune from lund, pbd, and only wanting a mild 650-675.
Question: For those Whipple'd, does anyone road course / track them? Are you using for drag racing? Or just fun street driving.
Mine is for street use. I go on occasional fun runs with a crew on some high speed twisty's out in the country, but never on a professional course. Engine oil temps have gotten to 230 when I've been heavy on the throttle for an hour or so during those runs, but nothing too concerning. Just be sure to grab your cooling upgrades ie. Spal fans, 3-core radiator, MMR head cooling kit, Watter Wetter or Purple Ice Coolant additive's. I burned a little oil (maybe half quart) during that oil change interval when I was running the car hard, but its been back to no oil burn driving normal with the occasional spirited runsQuestion: For those Whipple'd, does anyone road course / track them? Are you using for drag racing? Or just fun street driving.
I have a 2007 GT500 convertible with a 3.4 Whipple and love it for drag racing and street driving. Also, have GT350R and thinking to add FI but have not seen anyone post with FI on the track
