recommended full synthetic engine oils
melwff
Danbury,CT
2021 Mach 1 M2486
Hello, I was reading the supplemental manual and it says Mach 1 engine needs to meet the WSS-M2C961-A1 specs. So, I was searching what full synthetic oils would meet this spec. Obviously, the expensive and hard to find Motorcraft oil. I also found a Mobil 1 x1 5-30, which I think is also branded as Mobil 1 advance performance, which is also hard to find.
Since this engine is similar to the Bullitt, I wonder if former/current Bullitt owners would chime in and let us know what full synthetic oils they use. Otherwise, just stay with the Motorcraft synthetic blend and change the oil more often.
I had no problem buying a case of Motorcraft full synthetic at my Ford dealer and got a trade discount.
GreenS550
Houghton, MI 49931 Oakland, MI 48363
Bob
2019 Mustang GT Premium 2020 Explorer Limited
gadgtfreek
Fairhope, AL
Jason
2021 GT Premium Shadow Black 10spd Auto
Any 5w-30 full syn is FINE.
OutWest
OutWest
SF Bay area
2021 Old Person Special Mach 1
As long as FORD WSS-M2C961-A1 is basically ILSAC GF-6, I think you can safely use Amsoil Signature Series 5W-30 which exceeds all the known factory requirements. It is not cheap, but If you are looking for the best Full Synthetic engine oil on the market like I do, AMSOIL Signature Series 5W-30 it is :)
After some research, you are correct @MakoShark. Basically Ford’s internal approval of the GF-6 oils (In this case the GF-6A?) Reading through some articles, mainly for emissions and maybe direct fuel injection? I would say the standards may be more important for the EcoBoost engines
NeverSatisfied
Pittsburgh
2021 GT 6MT Base
I use Kirkland with heavy track use in my PP2. Will most likely use the same in the Mach1. Cheap enough I just change often
EmCel
VA
Em
2016 mustang gt
Just wondering if anyone has used or heard of Idemitsu brand? Is it good?
Elvis66
High Desert California
Brandon
2019 mustang GT ..2014 Camaro ..72 Chevelle ..67 LeMans..97 4runner..2001 tundra
Shell is part owner of them .lots of hi end Japanese car use that oil ,never heard anything bad .
