Recommendations when Lowering 2019, Premium, PP1, Magneride, to keep alignment Correct
DougS550
Fishers, Indiana
Doug
Hi. I wanted to get members current perspective/Opinions as to what they had to do when doing a minimal lowering with Springs like the Ford Performance M-5300-W Springs on my GT . I am having a set of Forged wheels made and plan on running 285/30/19" on the front and 325/30/19" on the rear which will be a little lower profile, so I want to remove some of the wheel gap but, I do not want to make it to where I have to worry about scraping on speed bumps or driving into my driveway. I don't want to slam to the ground, just remove about an inch of gap.
- What did you you have to replace suspension wise, so the car can be aligned back into specs.
- I am also going to install the LP Bread and Butter Package with the Ford Springs.
I didn't know if their was something else people had found necessary to change when doing a 3/4" 1" Lower springs.
Thank you for your help
Doug
shogun32
Northern VA
you might want to try some quality time in the wheels and suspension section.
If you drop 1" you generally want the bump-steer kits and roll-center correcting lateral links.
All very well explained in the suspension section.
kz
West Chester, OH
Mustangs & F150
Doug
You don't need anything else to be able to align it to spec.
DougS550
DougS550
Fishers, Indiana
Doug
Thank you for your help. I just wanted the most current options from people.
