Recomendations: Besides LTH, What Other Mods For FI
DougS550
Fishers, Indiana
Doug
2019 GT PP1. Car will not see any drag or track racing, just spirited driving.
I am just now getting to my performance mods. I just Ordered LTH Long Tube Headers from Beefcake and will install when they arrive. I am thinking ESS G3X with upgraded G4 Intercooler, 10 rib belt set up, 800-850rwhp
- I want to use E85, so recommendations for an aftermarket fuel pump, I don't want to overdrive the OEM pump. And I don't want to replace fuel lines, just the pump.
- I would like to final tune on 105 pully.
- Any other great tuners like Wengerd you would recomend?
- Which street tires hook up the best and don't require a lot of prep heating them up before they track well.
- My Ford Roush service advisor said their would not be a need to replace the OPG unless I plan on bangging the Rev Limiter?
- What Axles are people running with this setup?
- What drive shaft recommendation, With "No" Vibration issues?
- Fuel rail upgrade?
- I plan on using 1050 injectors?
- Should I Upgrade the crank harmonic balancer or Bolt?
** Would porting the Intake Manifold be of benefit?
** I have already upgraded my suspension**
Any other recomendations as to upgrades, please list them
Thank You For
Your help.
LOL WUT
Illinois
19 GT
You’re going to need a full fuel system not just a pump to run E85 while boosted.
I’d take a look at the Fore return system, Arcane System, and Lethal system. There are many good options for which pumps to run with these systems.
My main advice is if you’re looking to run 800-850hp, build the fuel system to handle at least 1000. You’ll want upgraded fuel rails and the IDX1050s are great injectors. I am not certain on their HP limits but they can handle 850hp just fine.
DougS550
DougS550
Fishers, Indiana
Doug
Who makes a high quality, reliable complete fuel pump assembly and a plug N Play complete return fuel system. And I will replace my fuel rails. Let me know who you have seen great reviews on.
LOL WUT
Illinois
19 GT
Fore and Lethal are the likely the most plug and play. Any fuel system is going to require some level of wiring (it’s simple wiring) and routing of hoses.
If the Arcane system had pre made fuel lines it’d be equally plug and play as the other two mentioned.
I can’t say that I’ve seen a bad review on any of them though.
DougS550
DougS550
Fishers, Indiana
Doug
I like Lethal. And I don't mind making my fuel lines and harnesses but, I would prefer not yo. Thanks
