Of course we are biased on ours. The big difference between ours and others is the fact that we rosette weld the bungs in place along with the standard full weld around the bung. Rosette welding makes sure the bung can't wobble in the tube which will eventually lead to weld failure if it's cycled enough. We also use a chrome-moly rod end with a stronger liner instead of the more common PTFE liner or slot loaded rod end.
