WD Pro
- Jan 18, 2018
- United Kingdom
- Lime GT
- Vehicle Showcase
- 1
Are you referring to the main hole in the back ? Should that not be plugged / sealed with the factory style bulb holder ?I’m convinced the expensive ones are made in the same place as the cheap Chinese ones !
The failure is down to water ingress. You need to seal the hole at the back of the light unit with silicone sealer. Once you’ve done that you won’t have an issue.
Cheers,
WD
