Rear Marker Lights Install
Alfa Male
Worcestershire Sauce Country
Alfa Giulia
I’m looking to refit the led rear marker lights in the rear bumper lower sides, from my old car to the new one.
Went to fit these last weekend only to find the 2018+ rear bumper design is massively different to to the 2015-2017 design. Not least I can’t see a way to thread the cable from the rear number plate lights to the rear markers as I had it installed in the last car.
Has anyone fitted these marker lights to a 2018+ model and if so how did you do the wiring ??
Eclipsar
UK
NFG Mustang GT
I moved mine from a 15-17 to a 19, can't remember exactly what I did but I remember removing one of the number plate lights and feeding cable down then running along to each side, if you want I can take a look under the bumper to see what I did, just let me know
Symone
Robin Hood county U.K
Simon
2021 mach1 grabber yellow A10
Just fitted mine from the 2017 to my 19 fitted markers in passed wires around inside of bumper then popped the number plate light out and grabbed wires through hole , didn’t encounter any issues
Alfa Male
Alfa Male
Alfa Giulia
if you could that would be most appreciated. I’ve spent ages trying to fish the cable through the number plate light hole. If you could give me a steer on which way to go that would be a start
Symone
Simon
Used one of these pushed from outside and grabbed cable
Alfa Male
Alfa Male
Alfa Giulia
From outside through numberplate light hole into bumper
On my previous mustang I could simply fish the cable straight through the number plate hole and drop down to the underneath.
However on the facelift the bumper It looks like it’s double skinned and when I’m fishing it through I can’t seem to find a way through.
Might have to take the rear bumper off to do this.
Fatbob V2
Int' Yorkshire
If you want a more factory way to do this (worked for my 16 model), remove the inner boot trims, left and right and there are grommets on either side that will drop your loom right above the reflectors. Just watch around the exhaust.
I connected in to the the sidelight feed in the loom that runs across rear slam panel, under the plastic trim where the boot catch is. You get an earth there as well.
Can’t remember the wire colour but it will probably the same as the one that feeds your number plate bulb
Keeps all your connections inside and away from moisture etc.
Symone
Simon
Just keep trying it literally took me 30 secs to thread through
Manders Mustang
The Boss
Birmingham - United Kingdom
2016 Race Red Ecoboost
I did a '18 with them, same as Symone says, just open the left number plate light, toss the tables up and backwards and they'll land on the floor eventually if you push more in.
Alfa Male
Alfa Male
Alfa Giulia
Bloody hell why am I finding it so hard then ! Spent about a hour the other day endless trying to fish the cables through ! I’ll have another session in the morning whilst the wife is at work !
Manders Mustang
The Boss
It does seem awfully unusual you're struggling, try and go up first rather than directly to the front of the car... there are bits that look like they'd catch somewhat but nothing obscure in the way
Alfa Male
Alfa Male
Alfa Giulia
It wasn’t easy but I realised where I was going wrong ! You need to poke your fingers through the number plate light hole and then feed cable through using your fingers to poke it down between the gap (same gap wiring for number plate light wiring comes up from).
It’s effectively straight and straight down which is why the cable will not do this naturally. Also the edges of the number plate hole are sharp, very sharp !
