MustangCollector
been reading up on this past few days and i know lots of folks are saying it helps wheel hop etc and thats fine with me but my car does not have wheel hop anymore. I found the biggest improvement came from the upgraded shock coilovers for the wheel hop issues as i saw little to no improvement with vertical links or toe rods and the other stuff for the cradle. Like us all i tried everything 2 years ago before coilovers came out and low and behold the coilovers fixed it for good.
I notice when you lower these cars the LCA bushing is not centered and seems it has a cocked preload in the lowered suspension state. I always wondered about this being an issue for bind and suspension articulation and how it would affect the oscillations of the IRS on bumpy roads and ride quality.
So my questions to owners who did this and vendors who supply these parts does this LCA bearing upgrade improve suspension travel, articulation and even the effectiveness of the shock and spring dampening.? I am not asking this when the car is being launched but when driven on the street hard or normally,
the labor doesn't seem that hard as i own a press and have the means to do it but im not sure if this is something that would improve things or not on the bumpy streets i drive on daily. My car handles incredible, it could ride better out back and i also wonder if the toe links and vertical links in combination with the offset load on the LCA bushing is actually affecting the IRS movement to absorb bumps without bind. I did test months back with the rear spring removed and a jack under the rear hub the up and down motion with no load wasn't as smooth as i would have expected, it almost seems the IRS wants to turn in and the vertical links prevent this and there is opposing preload on the LCA bushing as well.
technical comments welcomed here, i don't need replies on wheel hop as i am asking specifically for IRS bind and articulation in regards to ride quality.
