Rear IRS gears
chuckty101
Ontario
2016 Shelby GT350 Shadow Black
I have no interest in higher gear ratios, im personally only interested in a Detroit locker. But from what ive gathered our super 8.8 is the same size housing as a 9 inch rear.
So why no aftermarket stuff for this super 8.8?
Hi-PO Stang
Minnesota
2014 Shelby GT500
If the housing is too small, Ford Motorsport needs to come out with a larger housing with the 4:11 or 4:56 gears already installed. However , I think there should still be a way to make a 4:56 work in the current housing. Might have to get the grinder out and remove some metal from the housing to make the gears fit. I remember grinding metal away from the pinion housing on 9 inch rears to get 5.76,5.83, and 6.00 gears to fit.
200MPHCOBRA
Liberty Tree Needs Water
Louisiana
Greg
2013 BOSS 302
Where are the gears already. These cars need 4.30's. US Gear was supposed to be releasing some in the second quarter of this year, call them and get them cracking.
Hack
Minneapolis
Mustang, Challenger
Ford does have 4.09 gears available for the Super 8.8. There was another thread about it on here. I'm thinking if I spend the money to change I might want a bigger change.
TonyJ5150
Indianapolis, IN
2016 Shelby GT350
The 4.09 is out, but not the technology to correct the speedo after the swap...so I'm told...once that issue is resolved I'm doing the 4.09s for sure!
Voodooo
Voodooo
SE Michigan
Scott
Carroll Shelbys Soul Lives Under My GT350 Hood
Whipple has a solution for that, it's called the "flare device" $275.00. But I too am not gonna waste my time on a 4.09 gear set. Bring me a 4.56 then Im ready!
Darkane
Alberta
2016 GT350 Base
Can you point me to that thread? Can't seem To find it
302toVoodoo
Wisconsin
In Sport Mode ... ALL THE TIME!
Coulda swore I saw Ford Performance 2015+ compatible 4.09 or 4.10 gears in the parts catalog...
