Rear Camber/Toe adjustment on stock suspension
crimson_crowd_eater
Daytona Beach, FL
Tony
2018 Mustang GT Premium
Is there any way to adjust camber and toe in the rear on the S550 with completely stock parts? I called Firestone because I noticed my rear passenger wheel has a lot more camber than the driver wheel or either of the front wheels. In contrast, my driver's rear wheel has inward toe, while the passenger side is completely straight. The Firestone guy said that they'll do a free check, but he said "as far as he knows" there is no way to adjust the rear camber or toe, even though I've read differently.
Can anyone show me how to adjust it (with pictures preferably) on completely stock parts? I've seen that there's a bolt that can be moved and it should adjust both at the same time, but I'm not sure where it is.
shogun32
Northern VA
asked and answered multiple times. and each time to the affirmative. And even handy diagrams pointing out the bolts in question.
crimson_crowd_eater
crimson_crowd_eater
Daytona Beach, FL
Tony
Can you maybe link some of those threads then? I've found some but they usually have caveats like "I have BMR links" or "I just installed new lowering springs". It would be helpful if you could link some of those threads since they are so plentiful.
kz
West Chester, OH
Mustangs & F150
There absolutely is and it takes about 15 seconds of looking at toe link to figure out how. Camber adjustment is at the upper mount of the camber link (deeper in the subframe) - undo the bolt and shift the link towards either side. Ford's shop manual shows this clearly that any show should have access to.
I'm bored so see the pics from the manual. Dude has to be literally blind to not spot toe adjustment...
crimson_crowd_eater
crimson_crowd_eater
Daytona Beach, FL
Tony
Thanks. I'm guessing the top picture is for toe adjustment and the second picture is the camber?
kz
West Chester, OH
Mustangs & F150
Correct. Also, meant shop not show when I wrote any "any .... should have access to". Shops typically use the software with all the manuals in them (forgot the name), but pages would look exactly the same like what I attached. And this has not changed since 2015...
I would seriously reconsider using that shop, another question is how well their rack is calibrated....
Norm Peterson
corner barstool sitter
Norm
'08 GT #85, '19 WRX
This ^^^
That Firestone guy sounds like he just doesn't want to mess with rear wheel alignment and that was his polite way of saying "go away".
Norm
crimson_crowd_eater
crimson_crowd_eater
Daytona Beach, FL
Tony
This ^^^
Norm
Oh yeah, definitely. I just wanted to see what they say with the free alignment check. After he said that there was no way to adjust, I looked for other shops.
