Random misfire and LTFT negative.
LouisiAnimal
New Orleans, Louisiana
Cory
2019 Mustang GT 6 spd
I’m having this issue that I can’t seem to figure out. I get a code sometimes for Random misfire on startup and sometimes I get a code for misfire on 1. I can feel a miss about 1800 rpm only when I’m not heavy in the gas. Can hear an occasional mos in the exhaust when idling. LTFT gets between -15 and -20 STFT stays around 0. Tuner said my injectors might be stuck in open. Got em cleaned, Cleaned injectors, new coil pack and plugs, evap purge valve seems to be working, but hadn’t changed it. I moved the injectors to different cylinder after cleaning, and also moved coils around to see if the mis followed. It didn’t. I changed upstream o2 on that bank. Idk where to go from here. IMRC locked out.
17 gt w/18 ported mani, catless headers, full exhaust, t56 swap.
LouisiAnimal
Cory
Only things I can think of that are left are a vacuum leak or something internal. Maybe a compression or leakdown test is in order.
I thought vacuum leak would cause it to run lean? just in case I searched around for a leak. Sprayed carb cleaner around the manifold etc nothing to be found. I do hear a random tick from the throttle body at idle. I hear that’s normal though.
LouisiAnimal
Cory
Still fighting this issue. Ford dealer says there's un metered air after MAF. Wouldn't that create a lean instead of rich? Also p0300 p0308 p0316 He's changing the MAF, and wan't to put the stock intake tube on it. I'm tuned for the JLT, and have an 18 mani on it. I can't flash to stock, and I'm not sure it'll run right with the JLT tune on a stock Intake tube.
Robottrainer
Canada
2018 Ford Escape. 2020 Jeep Cherokee. 2021 Ford Mustang GT Stage 2 Roush
If you can't
If you can't find anything wrong, try reloading the tune. It happened to me on a 2013 Shelby
