Quick Question ! Does a new Trans need to be programmed to my car?
thegtway
Alabama
Arhmad
2016 mustang GT
We are replacing the 6r80 transmission in my 2016 mustang GT (not replacing anything computer related). After completed does the car need to be taken anywhere to get the new transmission programmed to my vehicle or should my car learn the new transmission on its on ?
fmc_smt
Cottonwood , Arizona
Needs to be programd
Yep - and you need to do a crank relearn procedure as well after the trans has been programmed. Anytime there is major engine or trans work performed, a crank relearn is mandatory.
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
As long it’s from the same generation, and from a Mustang GT, no programming needed. No crank relearn needed, but always good practice.
fmc_smt
The pcm needs to be programed to the replacement transmission/valve body . The solenoids in the main control have different flow rates and need to be programed into the pcm .
  1. If a new main control was installed, record the 12-digit solenoid body identification and 13-digit solenoid body strategy from the replacement solenoid body tag provided with the main control service kit. Place the replacement tag over the existing identification tag.
    • 13 - digit solenoid body strategy
    • 12 - digit solenoid body identification
Cory S
Bradford, NH
Cory
Mine didn’t require anything when I put in my latest PBH tranny. 1600 miles on it and shifts/performs exactly like it did with my previous one. PBH said it’s not necessary as well. If it was from an F-150, that would be different.
fmc_smt
Right out of the service manual .
  1. If a new transmission or a new main control was installed, the solenoid body strategy must be updated.
    Refer to: Transmission Strategy Download (307-01 Automatic Transmission - 6-Speed Automatic Transmission – 6R80, General Procedures).
Cory S
Bradford, NH
Cory
This may only apply to “New” PCM’s and “New” valve bodies.
Traviscm17
Austin,TX
Chaim
2016 Ford Mustang GT
I just dropped mine. Bout to install it and per seller they say to reflash it. But I’m boosted now so would just reflash my tune after install and top off? Then go through gears to make each engaged?
Traviscm17
Austin,TX
Chaim
All you need to do is reflash the car with your current tune and it will update the TCM to the previous config, since it has a new TCM on the new trans.
