2015 Auto Trans 6r80 Broke does the new one need programming?
Mudhar17
2015 mustang gt
Hi everyone, My trans broke( OD clutch) so I can no longer shift into 4-5-6. So I got replacement from salvage car from 2017 and my car is 15 mustang gt. Will I need to reprogram anything? My car is whipple so its tuned already so do I flash back to stock before and then reflash after the install? I read that you dont need to do any programming for the transmission if its from same generation. Please let me know
John S
Novi, Michigan
2022 Mach 1 HP
Arent the engine and transmission are controlled by the same computer? A replacement transmission will communicate shift times to the computer and adjust the valve body flows and pressures to "teach" the transmission's shift performance according to your existing tune.
Mudhar17
Mudhar17
2015 mustang gt
If that's the case, should I flash the car back to stock before removing and replacing the trans and then reflash after its done?
Johnny Rockit
Massachusetts
Johnny
2022 Mustang GT 6-speed. 2015 F-250XLT,73 Torino
If I read John S's post cirrectly, you don't need to do anything. The computer already speaks to the transmission and uses the same parameters as the failed unit.
