Question for those running Viking Warrior shocks
Volstang
Knoxville, TN
Randy
2015 Mustang GT
Thinking about adding these to my car. I only have a tune and CAI for power mods at this time. I have the BMR Cradle Lockout, BMR 81/88 springs (rears are drag spings), and diff bushings. I run M/T ET Rs 275/40-17s at the track and I'm not able to get below 1.90 60 ft times with my auto (3.15). I've tried various launch techniques and sometimes I can blow the tires off on launch. Wondering if/how much these might help. Anyone running these with a NA auto car and if they helped 60ft times.
BMR Tech
Tampa, FL
www.bmrsuspension.com
Dion
You can make that car with those mods spin a MT "R" drag radial!?!?
Dang.
BMR Tech
Tampa, FL
Dion
To answer your question, it depends on how the car is blowing them off.
If it is blowing them off "instantly"....I am afraid that a shock wont really help your specific scenario.
If it is hooking THEN spinning, then a shock will 100% help.
I feel you may need to look further into your traction issues.
For comparison, I had a 420rwhp tune up on just a MT DR on a 20" wheel (non R) and I could launch it from 6500rpm and it wouldnt blow the tires off. On two different tracks.
Volstang
Volstang
Knoxville, TN
Randy
2015 Mustang GT
I blow the tires off when I foot brake to 1000 RPM then floor it on the 3rd amber. It's like it hits the stock stall harder than when I foot brake to 1500 and completely load the suspension before hammering it. I can't get my 60 ft times below 1.90
JmalB
Tucson, Az
2004 Dodge NSRT-4, 2015 Mustang GT PP
What psi are you running in the tires?
BMR Tech
Tampa, FL
Dion
I am going to take a stab and say your issue is:
-Tire Pressure
-Track Prep
-Burnout issue
Or the culmination of all 3, which is actually pretty common.
Volstang
Volstang
Knoxville, TN
Randy
2015 Mustang GT
Tire pressure is 15-16 psi, I do a burnout just long enough to get a bit of smoke. Track prep varies. Maybe I can do a longer burnout. What tires pressures are others running in M/T ET Rs?
